It is currently Sat Nov 14, 2026 9:43 am
 Post subject: Relay number
PostPosted: Sat Apr 17, 2010 5:42 am
If I want to put a relay on an electric fan as recommened.What is the part number I am looking for? It seems people just grab them at the yard and use them off about anything. Sorry, I'm not that bright electrically. I searched some but didn't find a part number other than Dan's delayed timer one. I'm headed to Advance or NAPA in the next hour. Will either of these places have a suitable relay?
Rick
PostPosted: Sat Apr 17, 2010 6:49 am
have a look at this catalogue ,you can pick which type you want from there.
I do'nt know if Narva is sold in the US,but it should help you.
regards,Rod :D
 Post subject: Dorman
PostPosted: Sat Apr 17, 2010 7:13 am
Picked up a Dorman 84601 at Advance.
Thanks,
Rick
PostPosted: Sat Apr 17, 2010 12:21 pm
Watch out for dorman realys, the one i picked up from autozone didn't work............. keep an eye on the temp gauge!!!!!!!!
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Apr 17, 2010 3:10 pm
Watch out for autozone. Period.
PostPosted: Sat Apr 17, 2010 7:23 pm
good advice
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Tue Apr 27, 2010 3:31 pm
Tyco (formerly Bosch) is the only brand of relays I use.
They're still as good as when they had the Bosch name.
You can get them off eBay pretty cheap, too.
 Post subject: Dorman Crapped out
PostPosted: Wed Jun 02, 2010 3:02 pm
As some had mentioned the Dorman relay shorted out at Mason Dixon at the races.It was only in use for a couple weeks. Probably for a couple hundred miles tops! Charlie had a Bosch(I Think) relay which was twice as heavy as the crappy Dorman I bought. Live and learn.
Is there a Tyco Part # for the 5 pin relay I can look for?
Found them on E-bay:
12VDC 30 amp 5 pin Tyco relays. Part number V23234-A1001-X036.
