It is currently Tue May 19, 2026 5:37 am
 Post subject: Need to drain coolant?
PostPosted: Sat Apr 17, 2010 9:25 am
Do I need to drain coolant from my /6 to change intake/exhaust manifolds?
Do any of the bolts or studs go into water passages? Thanks
PostPosted: Sat Apr 17, 2010 9:26 am
Yes, there are head-to-manifold studs that go into the water jacket, but they 'should' stay in place.
Yes.
PostPosted: Sat Apr 17, 2010 9:36 am
So if the studs don't break loose, I can get away without draining or not?
PostPosted: Sat Apr 17, 2010 9:52 am
No need to drain if they stay in place.
11.02 @ 120.56
Chassis dyno
PostPosted: Sat Apr 17, 2010 10:21 am
True, you don't have to drain if the studs stay in place.
But I've found it's easier to drain ahead of time, then you can focus on finishing the job at hand, rather than cleaning up antifreeze off the garage floor. :D
Users browsing this forum: Bing [Bot] and 6 guests
