It is currently Wed Nov 18, 2026 4:06 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2
PostPosted: Sun Apr 18, 2010 1:19 am
The outer seals job is only to keep the bearing grease in and dust out of the bearings. If the inner seal fails, the outer will not keep axle oil from leaking out and will ruin the bearings. Been there, done that.
PostPosted: Sun Apr 18, 2010 8:34 pm
Car Model: 1968 A108 225/3 on the tree
that's what i was hunting for. the voice of experience.
i think i may have caught it b4 it took out the bearing. guess i better take a really good long look again.
thx
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
2003 Ford Ranger XLT extra cab
1997 Geo tracker(Suzuki Sidekick)
PostPosted: Tue Apr 27, 2010 5:32 pm
got the gears back in and about ready for the axles.
if i fill the bearings with grease before insertion, should i also fill the bearing cavity or would that be putting too much pressure on the gaskets.
D~~~!
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
PostPosted: Tue Apr 27, 2010 5:38 pm
Just "pack" the bearing with grease and install the axles.
PostPosted: Tue Apr 27, 2010 10:49 pm
What Doug said..I like to use one of them needle fittings on my grease gun to get between the rollers. I also use a big socket (can't remember the size) to pound in the inner seal. Its a socket used for Dodge and GM truck axles on 4X4 trucks.
PostPosted: Wed Apr 28, 2010 5:37 am
i have one of those needles too. that is what i'm planning to use.
i made my own "seal pusher inner" this time. i don't have one of those sockects u mention.
i got some whit PVC plumbing adaptors. the closest size to the bearing cavity was just a bit too large in diameter. the wire wheel on my grinder motor allowed me to shape it to the size i needed, it went in quite niceley this time.
i'm hoping for better results this time.
D~~~!
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
PostPosted: Sun May 02, 2010 8:53 pm
axles in and sealed up today. add some 6* pinion shims and got the drive shaft setting at approx 1* neg when stagnant.
just need to bleed the brakes and get the wheels back on to find out if that inner seal did the trick. axle end play is set at about .015".
thx for the input!
D~~~1
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
 Post subject: sure grip parts
PostPosted: Mon May 03, 2010 8:19 am
I have found everything I need on E-Bay..............and I do mean everything. From mopar kits to aftermarket lockers. even found parts that were repopped like that small pin. the green brgs have improved to the point that you can use them everyday...........just don't go driftin or road racin with them.
best regards ..max
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Tue May 04, 2010 9:32 pm
first test 2nite. no leaks so far. nice and quiet. . . . .
68 A108
73 Harley Servicar
71 BMW R75/5
48 Indian Chief
