It is currently Thu Jun 25, 2026 4:39 am
PostPosted: Fri Apr 16, 2010 5:58 pm
I have looked a lot here about the dampener for my slant which turns out to be a 1978 block with a cast crank.The dampener is shot and I am forced from a $ standpoint to look at a few used dampeners but they are all pre cast crank units. From what I have come to understand these should be OK for an auto trans cast crank vehicle yes? I know it is not great using an old unit but the money needed for a new one is not available right now.
Thanks
Howard
Hampstead, NC
65 4-door Dart
70 Chrysler 300
2004 Cummins Ram 3500
1968 Dart GT Convertible-project
Chordomafoundation.org
PostPosted: Fri Apr 16, 2010 6:01 pm
I keep seeing new ones on ebag for under $50.00
PostPosted: Mon Apr 19, 2010 2:23 pm
I've looked on hebay for weeks and have not seen anything under vibration, dampener, vibration???
65 4-door Dart
70 Chrysler 300
PostPosted: Mon Apr 19, 2010 3:06 pm
Dampener means a device or system that applies water or some other liquid to wet (dampen) some other device or area.
Damper means a device or system that controls unwanted movement, noise, or vibration.
Keep watchin'; they do go across eBay with pretty good frequency.
PostPosted: Mon Apr 19, 2010 4:02 pm
So the damp water pump was a dampener for the damper...............
PostPosted: Tue Apr 20, 2010 5:00 am
i too will need a dampner soon. will this work for my 71 with an auto?
http://cgi.ebay.com/ebaymotors/SLANT-6- ... 53e0d8f231
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
 Post subject: Yes and no...
PostPosted: Tue Apr 20, 2010 5:20 am
The 6 spoke in that auction would be what PPSI is looking for (never seen one drilled for balance like that...). The 1971 needs a 3 spoke damper for the forged crank...they can interchange but the cast crank damper is lighter than the forged crank version by a smidge.
PostPosted: Tue Apr 20, 2010 7:39 pm
I'm pretty sure any of the forged crank dampers would work, as long as the requisite number of pulleys is present. I bought one off feeBay and I think even with shipping it was under $50, new in the box.
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
