It is currently Wed Jun 17, 2026 12:32 am
PostPosted: Wed Apr 21, 2010 6:50 pm
Dorman/HELP valve cover grommets part numbers for a 1985 slant 6 (other years may apply)
Breather grommet part number is 42344. It's labeled as a pcv grommet but it works,it has (6042344 M CHINA) molded in it as big as can be.
PCV valve grommet part number is 42065. It has (65 taiwan) molded in it.
I started this thread because i kinda had to search for the numbers and it wasn't super clear.
I hope this helps anyone with cracked hard grommets.
P.S. can someone follow up with part numbers for the early type valve cover grommets (the ones with only two holes)
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Thu Apr 22, 2010 1:08 pm
Early type cover '66 to '69 uses only one grommet, same PCV valve grommet as you list here for '70-up cover. '60-'65 covers do not use grommets.
PostPosted: Thu Apr 22, 2010 2:12 pm
This is a very timely post - I was cleaning my old grommets today in the laundry tub and voila! - I washed the pcv valve grommet straight down the drain - after the initial scream I started to laugh hysterically - damn funny $#!+!
Danke for the part #'s - I see a trip to Can Tire in my future :)
Peace
The car I am restoring is a 1971 Valiant 4 door with a slant 6 - 225 engine.
PostPosted: Thu Apr 22, 2010 2:23 pm
Thanks Dan I knew they were different somehow,glad to see this is helping. :D
85 d-100 HEI 2BBl
06 Toyota Corrola
Users browsing this forum: Bing [Bot], Google [Bot] and 4 guests
