It is currently Sat Jun 06, 2026 11:28 am
 Post subject: Hot Intake
PostPosted: Wed Apr 21, 2010 12:23 pm
This is on my '78 Volare's 225. I have an Offenhauser intake with a 2bbl carb on top, and a modified rear manifold. The intake and rear exhaust manifold are not bolted together, there is a gap between them. However, after driving around for awhile in warmer weather, the intake feels pretty hot. I was just wondering if this normal, I don't remember how hot the stock intake/exhaust combo felt.
I'm really just curious.
Wes
'78 Volare 225
'67 Charger 318
PostPosted: Thu Apr 22, 2010 9:25 pm
It's normal, an aluminum manifold will heat up faster then a cast iron manifold. A cast iron one will retain the heat longer. Inline engines need some heat in the manifold to help with air/fuel distribution.
PostPosted: Fri Apr 23, 2010 9:40 am
Okay, thanks. I guess I never really noticed before how hot the intake got when it was stock.
Thanks!
'78 Volare 225
'67 Charger 318
PostPosted: Fri Apr 23, 2010 9:56 am
Wes,
I really like the aluminum intake manifolds on the SL6. They help to shorten the heat soak especially on hot days since they cool faster and warm up much faster in the dead of winter for much better drive-ability especially when you have a electric fan and a super free flowing exhaust system with larger exhaust pipe. The engine gets much better mileage and runs cleaner.
Also, much less time with the choke engaged.........
PostPosted: Fri Apr 23, 2010 5:07 pm
Thanks Ted! 8)
'78 Volare 225
'67 Charger 318
