It is currently Tue Jun 16, 2026 10:32 am
PostPosted: Wed Apr 21, 2010 7:15 pm
I need exhaust hanger brackets for a '75 Dart, and would like a few sets of kickdown/throttle/choke thermostat linkage clips. What is the best source?
Never seen a Valiant I didn't like!
PostPosted: Thu Apr 22, 2010 10:16 am
I just saw that the local Advance "Help" section had packs of such things - probably there are better sources, but less convenient.
PostPosted: Thu Apr 22, 2010 1:26 pm
Use new style exhaust hangers (round rod tack welded to pipe or muffler, rubber bushing bracket at floor pan).
Dorman and Echlin sell multi-packs of the clips.
PostPosted: Fri Apr 23, 2010 5:18 am
Those clip packs do not have the small clips for the choke rod. Just went threw that. I haven't been able to find the small clip in a parts store. Found one on a old carb. That clip is still available from the dealer, but I can't find the part number, right now.
PostPosted: Fri Apr 23, 2010 9:06 am
The ones I've bought always have — and I wind up with a bunch of other-size clips I can't use. You can get the correct clip individually, too; Dorman # 118-005 or 118-025 depending on whether you need the RH or LH variety for the 1920/BBS/W or for the 1945/6145 (don't have which is which in front of me).
PostPosted: Fri Apr 23, 2010 9:29 am
Thanks!
PostPosted: Sat Apr 24, 2010 4:05 am
I stand by my statement. The part numbers you list (which are the smallest in the "multi pak", are for a 5/32 inch rod. The slant six choke rod is 1/8 inch. It might be made to work, but will not fit properly.
The correct clip is Chrysler part number 2465560 which is superseded by 4041917
I just went through this about 2 weeks ago. Customer bought a 76 Valiant for his daughter, and I had to replace a missing choke t-stat.
PostPosted: Sat Apr 24, 2010 4:57 am
hi, tom at accurateltd.com has slant 6 exhaust hangers and exhaust systems for slants. they are very helpful. ron
PostPosted: Sat Apr 24, 2010 9:32 am
Okeh. They work for me.
That's for the 1945/6145? Or for the others?
