It is currently Tue Nov 17, 2026 10:39 pm
PostPosted: Thu Apr 29, 2010 2:46 pm
Can I swap 48k valiant rearend into to my wore out 146k dart both auto slant 6, also will front spindles swap? Thanks
PostPosted: Thu Apr 29, 2010 6:09 pm
The rear is a straight swap. The bolt pattern will now be LBP though.
If you bring over the front disks....you need to do the FULL swap.
UCA, spindles, shields, calipers, prop. valve, hoses and MC. LCAs are fine. If your 74 is a power brake car, the MC is not the same as a manual pushrod.
