It is currently Tue Nov 24, 2026 1:10 pm
 Post subject: engines
PostPosted: Tue Jul 08, 2003 6:52 pm
:roll: hi can any one help me get started on my engine iam haven a hard time findingany thing on a 225 engine like chrome parts an bore it out how much can i i just wont too make this 6 fast an well chromed please help me out bye emailen me at hdpan666@aol.com mopar gone nuts i need help? :(
PostPosted: Tue Jul 08, 2003 11:03 pm
Chrome valve covers are on ebay. You can buy aftermarket generic chrome breathers and pcv, as well as steel braided hoses. You can get an aluminum intake and polish it, will be close to chrome. For the rest you can either chrome plate or use aluminum/silver spray paint.
As for boring... most are typically done 30 or 60 over, with some blocks capable of going to 100 over I believe. You can do lots of things to squeeze more performance out of your slant. First off, what car is it in? Basic upgrades include removing lean burn if you have that system... ignition upgrade. Something a bit more costly would be getting a completely different intake setup, such as a supersix or 4 barrel or dual webers.. plenty of possibilities there. Then upgrade exhaust, and rear end ratio. Lots of upgrade paths and possibilities, look at the articles availible on this forumn and start reading some posts.
PostPosted: Tue Jul 08, 2003 11:42 pm
A good tune-up and advancing the timing can really purk-up a SL6.
If the engine is 1979 or older with a mechanical cam, a valve adjustment will also help.
Jump-in and keep asking questions.
Users browsing this forum: Bing [Bot] and 8 guests
