It is currently Wed May 13, 2026 11:04 am
PostPosted: Mon May 03, 2010 8:08 am
OK...I need some instructions please.
My daughter came home with her 225 /6 64 Dart yesterday with it not running very well. When they left the house...it was running just fine. When we bought the car...we found the points had came loose causing it to run about the same as what it was doing yesterday. I checked the points yesterday and the points were just fine. Pulled the radiator cap off and found oil in the cooling system. Check the oil and it was right where it was before they left.
Pulled the plugs and they didnt look contaminated.
How would I check to see if its a blown head gasket of a cracked block? I dont want to just start pulling it apart and find it wasnt either one...
Thanks
Rick
PostPosted: Mon May 03, 2010 8:13 am
One sign of a possible blown head gasket is lots of coolant smelling steam coming from the exhaust pipe.
 Post subject: blown head gasket
PostPosted: Mon May 03, 2010 8:21 am
check the exhaust for antifreeze.
Can't miss it .tastes sweet.
take care...max
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Mon May 03, 2010 8:26 am
Is the car an automatic? Maybe the trans cooler in the radiator is leaking ATF into the cooling system.
You may want to retorque the head, re-adjust the valve lash, flush the cooling system and add a can of stop leak... I would try that before taking it apart.
PostPosted: Mon May 03, 2010 8:37 am
Yes it is an automatic but the cooling lines dont go thru the radiator...it has its own cooler out front.
Do those stop leak additives work that well?
Will try the doing the head bolts...
Thank you
Rick
PostPosted: Mon May 03, 2010 10:44 am
Dont know if this makes and difference but... I can pull the radiator cap off and I find old dark oil in the top but if I take the lid off the coolant flush T...the coolant comes out clean. Fresh anti freeze is what comes out.
Rick
PostPosted: Tue May 04, 2010 6:13 pm
Well...I have done the following
1. Replaced points with a pretty good set that I had here around the house.
2. Pressure tested the cooling system and it tested fine. No bubbles and it held pressure.
3. Retorqued head bolts just for giggles.
Results...
Still bad idle...
No smoke or steam from exhaust.
What else could I test???????
Thank you
Rick
PostPosted: Wed May 05, 2010 4:33 am
In the time that it was running fine and came back did she get gas? Maybe she got a tank of water.
64 dart GT /225
...........____ .
...._n_.[____].
.....L\....\......
.......\____\....
PostPosted: Wed May 05, 2010 9:19 am
Car Model: 1979 Dodge Aspen
i have had the carb come loose on the manifold check that
PostPosted: Wed May 05, 2010 10:12 am
No gas was added on this little trip.
This morning I check the vacuum lines to make sure one had not come off and then I did a compression check and compared it to the one I had did about a week ago when we got the car. Numbers were the same in all cylinders...+ or - a little.
Could a bad condensor cause this kind of idle issue?????
thank you
Rick
PostPosted: Wed May 05, 2010 10:36 am
Condensors do break down over time. It wouldn't hurt to replace it. You might want to give a peak at the bottom for the float bowl and see how much water is in there.....or rust....
PostPosted: Wed May 05, 2010 11:16 am
ok...I forgot something that happened when we first got the car. I reached down to adjust the dist. and it shocked me. Didnt touch anything except the base and cap..
Any ideas???
PostPosted: Wed May 05, 2010 2:56 pm
Adjust the idle mixture according the procedure specified in the FSM.
Adjust the valves.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed May 05, 2010 3:04 pm
Already done! Both the valve adjustment and idle adjustment was right on.
I have new plug wires,cap,rotor and condenser on the way.
PostPosted: Thu May 06, 2010 6:49 am
ok..I replaced the plug wires,cap,rotor and condenser and its running like a top. All I need to do today is flush the cooling system out and fill it with water. I will watch it for a few days to see if the coolant gets oiled down again.
Thank you for all your suggestions..
Rick
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
