It is currently Sat Jun 13, 2026 9:26 am
 Post subject: Garage Floor Coating
PostPosted: Fri May 07, 2010 10:02 am
Another slightly off topic question
anyone with experience on a "do it yourself" garage floor coating project.
The local Lowes carries Rust-Oleum and Quickrete epoxy floor coatings
The Rust-O brand has two color choices,, the Quik has 30,, anyone have experience with these products or doing this in general?
The prices to have this done professionally is not in the budget, but It looks like I could do a 2 car garage myself for around 150,, which fits my wallet.
thanks
PostPosted: Fri May 07, 2010 11:32 am
Clean, degrease, dry, repeat, repeat, etc. Apply product following all directions on can. Enjoy your lovely floor. Pick up a can for repairs, etc
Slanted D150
PostPosted: Fri May 07, 2010 11:38 am
Check out http://www.garagejournal.com/forum/ - this has been discussed several times over there. IIRC the cheaper coatings will lift when you park a driven car (hot tires) over it.
PostPosted: Fri May 07, 2010 12:05 pm
Poser
Dadtruck's garage is new construction (lucky dog) so the cleaning will not be as bad as a floor that has had vehicles parked on it. How is it progressing?
PostPosted: Fri May 07, 2010 3:30 pm
yep have some new construction going,, to house a "new to me vehicle",
I'll still be known here as DadTruck, but I also now have a 68 fastback Barracuda, slant powered, all original, 40K miles,, long story but it is a local find. Been in storage since 1972,,, now its mine and I'm building a garage for it and the 83 D-150,,,,,
regards,
PostPosted: Fri May 07, 2010 8:43 pm
Congrats on the new garage. :D
PostPosted: Fri May 07, 2010 9:30 pm
Car Model: 1967 Dodge Dart GT
its going to be a nice setup when its done!
PostPosted: Sat May 08, 2010 3:00 am
Epoxy based finishes when applied properly will stand up much better - I had my entire basement coated and have never regretted it - if you want color you could also talk to your concrete finisher and have him dye your concrete and then have him seal it not unlike any driveway you may have seen - the sealers stand up well and resist most car fluids.
Paint will eventually give you trouble in my experience and need repair.
I'd check the difference in concrete pricing first and then lean towards the epoxy finishes if the concrete solution is too expensive. Also ensure your floor wont crack over time - not always easy to ensure but I strongly recommend reinforcing material - mesh or fiber mesh or cut the floor - I hate cracks and if you paint it the crack will look awful if one ever appears.
Good luck on the new garage :)
Peace
The car I am restoring is a 1971 Valiant 4 door with a slant 6 - 225 engine.
PostPosted: Sat May 08, 2010 3:36 am
I do not know the answer-- but here in Wichita we have a company that polishes the concrete & it looks amazing!!!
I just thought I would through that out as an idea, Lawrence
PostPosted: Sat May 08, 2010 5:10 am
If you have your concrete contractor power trowel the floor it will shine like a mirror. This finish looks great once sealed but can be slippery when fluids reside on the surface - the same holds true for paint and the epoxy finishes - I had my garage floor power troweled and then sealed it with Thompson's as I recall - easy to sweep and definately the cheapest way to go.
PostPosted: Sat May 08, 2010 7:39 am
Poser
I wondered when Dad"Cuda"truck would debut this treasure! :lol: I have seen the car and believe me he snagged a good one!
PostPosted: Sat May 08, 2010 4:06 pm
I used the Quikcrete on my garage nearly 4 years ago, when it was brand new and so far so good; I do have one spot that "lifted" almost right after I did the coating; but my stand up freezer now covers that spot! I have had lots of vehicles back n forth over this stuff, and other than when I "chirped" the tires on my kid's Ramcharger, it has no black marks from hot rubber yet. I do need to get everything out (empty the garage) once I get me another power washer and hose down the floor; Brake Clean and rags are gettin expensive.....
PostPosted: Sun May 09, 2010 5:34 am
thanks for the feedback on the quickcrete,
with what I have gleaned from the garage journal forum, great info there also,
I'm putting together a decision matrix on the various products,
I'll post when I have it done
