It is currently Wed May 13, 2026 10:11 pm
 Post subject: Compression ratio, again
PostPosted: Mon May 10, 2010 9:30 pm
So I have my (75'-80') head in the shop getting 1.44 1.70 valves put in. After that we will cc the head, guessing avg of 60cc. so using a calc these are my figures, am I missing something?
What I have:
60 cc (guestimation)
3.440 bore
.175 deck
Felpro 3.5 & .037
stock stroke 4.125
= 8:1
I would like 10:1 and that means .100 (45cc) off the head and .045 off the block. I also have a Clifford 264 cam, 1.5 stock adj rockers w shorter push rodsand yes, damper dual springs.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
Last edited by hellion_locdogg on Mon May 10, 2010 10:06 pm, edited 1 time in total.
PostPosted: Mon May 10, 2010 9:48 pm
Stroke of a 225 is 4.125". You do have a 225 correct?
PostPosted: Mon May 10, 2010 9:58 pm
Yes and I'm a ritard that is why I asked... LOL Thanks let me change some numbers then and see where I'm at.
Thank you much Josh!
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Mon May 10, 2010 10:04 pm
Ok, so this is where I'm actually at 7.8:1. So .100 off 60cc is 45cc and .045 off the block puts me right at 10:1. Glad I asked, now I can bookmark this page.
,Cliff :wink:
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 11, 2010 8:26 am
If milling both the block and the head, I would take the heaver cut off the block & leave the head as thick as possible. (the block is a bigger, thicker, more stable piece of cast iron so it takes the heavy cut a little better)
PostPosted: Tue May 11, 2010 12:20 pm
Thanks Doc!
,Cliff
'72 4 dr Dart
'63 4 dr Dart
Users browsing this forum: Bing [Bot], Google [Bot] and 14 guests
