It is currently Mon May 18, 2026 8:44 am
 Post subject: Rod Bearing Question
PostPosted: Tue May 11, 2010 7:01 pm
Hey Guys , I have the motor out of my Valiant and have been checking things on it . I don't know how the bearings are supposed to look but thses look worn to me . The rod journal mikes at 2.187 in 3 places 120 degrees apart on all 6 rod journals ( so they are not out-of-round) . Can I just replace the bearings or should I have the crank inspected ? I hate being a rookie .
Thanks,
Steve
PostPosted: Tue May 11, 2010 7:21 pm
Those don't look too bad at all, I've seen a lot worse. The crank might need a polish and you're good to go!
Some people are like Slinkies, not really good for anything but they bring a smile to your face when pushed down the stairs.
PostPosted: Tue May 11, 2010 8:01 pm
I've also seen and run much worse. If the budget is tight you might just Plastigauge the clearance and if it's acceptable put those bearings back in. If the budget is a bit better I would have the crank cleaned and polished and use new bearings.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
