It is currently Thu Nov 19, 2026 10:14 pm
PostPosted: Thu May 13, 2010 5:41 pm
Does anyone know how to remove the place covering the speedometer gear? I took the fork like holder off, but the plate did not come off. I didn't want to pry it and damage it. Anyone have any experience with this issue? Thanks in advance for the help.
PostPosted: Thu May 13, 2010 6:03 pm
Assuming you have an automatic…
After removing the fork, the assembly containing the gear should pull straight out. All that is holding it is an “Oâ€￾ ring, and a bunch of crud.
Before you pull out the gear & cover or plug, give it a good cleaning than examine it for three sets of numbers, say, but not necessarily; (20-26), (27-34), (35-39) located ninety degrees from each other and how the fork relates to these.
The numbers indicate the tooth count of your gear. Low tooth count = smaller diameter gear, large tooth count = larger diameter gear. That cover that holds the gear, and the speedometer cable is an eccentric, so as that cover is rotated through 270 degrees it will adjust the placement of the different size gears that run off of an internal gear in the transmission.
PostPosted: Thu May 13, 2010 6:35 pm
6 Pack Dart
There is a small raised indicater on the transmission clean off around the area and you will see it.
PostPosted: Sat May 15, 2010 4:42 pm
Thanks for the help guys
