It is currently Fri Nov 20, 2026 12:20 am
 Post subject: 8 1/4 dissasembly ??
PostPosted: Sat May 15, 2010 6:51 pm
I have everything taken appart but we can not get the pinion to come out. I thought that once the pinion nut and yoke are removed it would just slide out through the back of the housing. This isn't happening what are we doing wrong?
The rear is out of a Dakota with out ABS
 Post subject: Bfh
PostPosted: Sat May 15, 2010 7:40 pm
Usually they do just slide right out...must be pretty tight.
Dod you give it a "pop" with a Rubber Dead Blow Hammer to see if that would persuade it?
:wink:
PostPosted: Sun May 16, 2010 4:40 am
It looks as if the bearing has rusted to the pinion shaft. We heated the bearing and did some whacking with a big mallet and then a hammer with a block of wood on the pinion nut. I guess we need to soak it with some croil. Thanks for the reply.
