It is currently Wed Nov 25, 2026 12:47 am
PostPosted: Wed Jul 09, 2003 10:45 pm
Ok
I wouldnt be being me if I didnt post another stupid question.
I got my super six all set up and it is running nicely. One thing I have to go back and do is dial in the curb idle a bit better. It is just a hair fast.
I learned how to adj the curb idle no problem but when I was setting my adjustments for the fast idle, I noticed that no matter what I did to that screw, it didnt change the idle with the throttle at rest. When I opened the throttle, the cam on the side of the carb still didnt contact the screw.
Basically I got the car to idle and run almost perfectly without messing with the fast idle adjustment.
So, what is it for and how should I go about adjusting it? The directions I used from the articles on this site reference setting it using rpm. Only problem is most 4 door volares dont have a tach so that information is pretty worthless to me unless I wire one up real quick (no time for that this week).
Advice appreciated
-DW
Dr Wheelie
PostPosted: Wed Jul 09, 2003 11:16 pm
The fast idle cam and adjustment screw should work when the engine is cold and on the choke. It will not contact anything once the engine is warm.
Here is more info on how the choke works, the operation is basically the same for the 1 and the 2 bbl system.
http://www.slantsix.org/articles/choke- ... adjust.htm
PostPosted: Thu Jul 10, 2003 7:26 am
Thanks for the advice
Although I have the choke stuff mounted up, it isnt hooked up.
I am in New Orleans and it is hot hot hot right now.
I am going to go back and hook it up though.
I had wanted to get everything else dialed in so I could make sure that the choke wasnt getting in the way of getting her running right.
I have seen the article you referenced and I am sure it will provide me with the info I need
Many thanks
DW
Dr Wheelie
Users browsing this forum: Bing [Bot] and 6 guests
