It is currently Mon Jun 08, 2026 4:17 pm
 Post subject: dart master cylinder
PostPosted: Sun May 16, 2010 6:29 pm
I have a 72 dart started leaking from the master cylinder where it meets the brake booster is there an o ring i can purchase to stop the leak or woul di have to buy a new master cylinder??
PostPosted: Sun May 16, 2010 7:17 pm
You need a new master cylinder (or you need to rebuild the one you have). New ones are still available; don't buy a "remanufactured" one. Does your Dart have disc or drum front brakes?
PostPosted: Sun May 16, 2010 7:30 pm
it has disc in the front drum rear with brake booster
