It is currently Wed Nov 25, 2026 3:32 am
 Post subject: Spark Plug Wires
PostPosted: Wed Jul 09, 2003 10:16 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
WHo makes a good set and has anybody noticed much difference between stock and hi-po?
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Wed Jul 09, 2003 10:55 am
I know Magnecor makes a set for the /6, Part# 6508, for 75 bucks. What I don't know is if they use larger boots on the distributor end, that our stock caps won't fit.
This raises a question for me though, do the electronic distributors have larger towers to allow for bigger plug wires?
PostPosted: Wed Jul 09, 2003 2:11 pm
No, they are the same as for the points distributor. I find that the cheap autolite plugwires work very well.
PostPosted: Wed Jul 09, 2003 2:42 pm
I'm using MSD Superconductor 8.5mm wires along with a msd coil/box. They don't make a set specific for the /6 but I bought a universal v8 set and had to cut/crimp to my own desired length. This way I also have an extra 2 wires. Heck with all the extra wire length you can buy the terminals/boots seperately and make another set.
 Post subject: make yer own wires...
PostPosted: Wed Jul 09, 2003 10:16 pm
I prefer making my own too, because you can route them exactly like you want. Besides, leftovers can make good wores for the riding lawnmowers lol.
Slant Six... out of the ordinary - just like me!
PostPosted: Wed Jul 09, 2003 10:26 pm
MSD wires for a lawnmower? heck no! way too expensive. I have about 3 or 4 used sets of /6 wires in the garage scatterd about if I ever needed any extra plug wires. All the universal sets I've seen were for v6 or v8's. The longest v8 wire easily has enough length for 2 /6 wires.
PostPosted: Thu Jul 10, 2003 8:42 am
:D
Thanks everybody. I went with a $30 set of Accel 8mms that were universal for an 8. Crimped 'em up myself, and they still seem to work.
Haven't noticed a big difference, but it does seem to run a little smoother.
Joe
Joe Hoppe
PostPosted: Thu Jul 10, 2003 12:10 pm
:D
Joe
I've used Accels in my truck and a friend's old Ford, and in both vehicles for some reason the mileage SUCKED with 'em. I much preferred stock wiring (or I would've gone with Magnecor given what I've heard about 'em). Course I guess if you're not building it up for economy then no bigge, eh? :P
PostPosted: Thu Jul 10, 2003 3:03 pm
The only time you might see a improvment in driveablility/mileage/etc with a plug wire upgrade is if they were crossfiring in the first place. Good way to check that is to take a spray bottle and fill it with water or water and a bit of soap and spray all around the plug wire area while running, and see if you see sparks jumping from wire to wire.
