It is currently Wed Nov 25, 2026 4:00 am
PostPosted: Thu Jul 10, 2003 6:41 am
I think that little pesky screw fell in there during a recent point swap, do I have to get it out? the car is running fine (right now), what will happen as far as damage?
PostPosted: Thu Jul 10, 2003 7:52 am
I really don't like the idea of little bits of metal rattling around loose anywhere in the car. I'm not sure what harm it could do, but why risk finding out?
I'd pull the distributor, invert it, and see if I couldn't shake the screw out. You'll have to reset the timing, but that's not a big deal for piece of mind.
PostPosted: Thu Jul 10, 2003 9:05 am
I think I got one out one time with one of those magnets on a stick type of things you get at the auto parts store.
John
PostPosted: Thu Jul 10, 2003 10:15 am
You must have more patience/dexterity then I do, changing the points/condenser on a /6 with the distributor in place! What body is it in?
Here's a tip. Next time you gotta change points, spin the motor so the rotor points at exactly 12 o'clock, or some other easily memorable direction. Mark the bracket where the bolt for adjusting the timing is located with a piece of chalk, or simply drag a screwdriver through the grease :wink: Your gonna have to reset the timing after a points change anyway, and you'll be in the ballpark. Take the bolt out and pull the 'stributor up where you can work on it and change the points condenser with ease. When you drop those screws, you can shake them right back out! If you want to take the wire loose from the coil, you could take the unit to your bench for extreme ease, but this is really unecessary. Put everything back like you found it, fire it up and break out the timing light.
"DW"
If it ain't broke, fix it!
PostPosted: Thu Jul 10, 2003 11:06 am
Better yet, change to factory electronic ignition or put a Pertronix electronic ignitionkit in it. Never change points again! I pulled the distributer to change points (when I had them) also. Electronic is pretty much set and forget. 8)
PostPosted: Thu Jul 10, 2003 8:23 pm
Thanks, I am going to go the EI route, just buying some time first. It's in a 71 valiant. I don't have a timig light so I'm going to try the magnet option first.
PostPosted: Thu Jul 10, 2003 9:26 pm
Best place to get a timing light is a pawn shop. I only paid 20 bucks for my Sunpro dial back light! 8)
PostPosted: Thu Jul 10, 2003 11:27 pm
I will cut you a deal on these tools:
http://www.slantsix.org/forum/viewtopic.php?t=5729
