It is currently Fri Nov 20, 2026 2:09 am
PostPosted: Tue May 18, 2010 7:49 pm
Car Model: 1969 Plymouth Valiant 225 \6
I have a 100% stock '69 automatic Valiant with 104,000 on it. It was originally my grandmom's, then sold to my brother, who ended up giving it to me. It's been garage-kept for most of it's life and my bro drove it slower than my grandmom(even though he is a fighter pilot). So needless to say, it's never been beat on, and is in pretty good condition.
I do get a strange "ting" sound though, and I believe it is coming from my driveline somewhere. It occurs at different times and sporadically. The two times it occurs most is:
1. When I reverse, then shift into drive it "tings" when the trans goes to drive.
2. When I'm driving at normal speeds, let off the gas to coast, then hit the gas lightly again to gain speed, it "tings" as soon as I hit the gas.
I don't know how else to describe the sound except a "ting". It is not a heavy clunk, thud or bang. It sounds like a thin, light piece of metal hitting another piece of metal. It almost sounds like people toasting drink glasses.
Other than that, it upshifts and downshifts quickly, firmly and smoothly, so at this point I'm not terribly concerned. I really don't want it to turn into something catastrophic though. My brother and I successfully changed the trans filter and fluid a few years ago and it is still clean since he put very few miles on it since.
Any ideas? I appreciate your replies. Thanks a lot.
PostPosted: Tue May 18, 2010 8:44 pm
Almost certainly not a major issue. At 104k miles it's a good bet that you're due for a new transmission mount (very easy to replace; get the one at the top of this page if you can save up for it) and one or both of your universal joints is likely ready for replacement. You might also have a bit of play in the rear axle ring and pinion—not worth pulling apart to correct; it'll live a very long time that way, but it'll be a fine idea to change the rear axle oil.
PostPosted: Tue May 18, 2010 9:21 pm
That 'ting" is the taking up of backlash in the rear end, but it's the driveshaft that rings. With the parking brake on and the transmission in neutral you can turn the driveshaft back and forth to get an idea of the amount of backlash. It's not a big deal usually.
PostPosted: Tue May 18, 2010 10:10 pm
Another thing to check is the flexplate to crank. Just remove the inspection cover, put the car in neutral not park w e-brake on. Give your torque converter a good shake and listen. You should know for sure if it's loose. Mine was for a long time before I ever heard noise out of it. By it had caused damage.
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue May 18, 2010 10:57 pm
No. This noise is related to driveline lash (drive/coast), so it is aft of the transmission's output shaft. The symptoms as described don't come close to pointing at any problem with the flexplate-to-crank bolts.
PostPosted: Wed May 19, 2010 12:46 am
Thanks for the replies----Dan that makes three. I'll have all of these things checked out at my friend's shop when I get it running again---have to do the exhaust manifold first. Like I said, it shifts great, but I don't want any part of my drivetrain out of whack. Once again, I appreciate the quick responses. Thanks a lot.
