It is currently Fri Nov 20, 2026 6:09 am
PostPosted: Wed May 19, 2010 1:57 pm
do i need to replace crush sleeve???? or can i just remove nut ,yoke ????...r&r seal replace yoke,nut & torque
PostPosted: Wed May 19, 2010 2:47 pm
You could always mark the nut, then count how many turns it takes to get it off....
Then when reinstalling, just put the nut back to it's original spot..........
PostPosted: Tue May 25, 2010 5:30 am
is this really that simple????
PostPosted: Tue May 25, 2010 8:39 am
Yes... I have successfully removed and re-installed the yoke on a C.S. type rear with-out problems.
You just have to be careful to no over or under tighten the nut upon re-installation.
The main pinion bearing position is set by a solid shim on a CS set-up so gear mesh change is not the issue. The crush sleeve sits between the front and rear pinion bearings and takes-up the slack / sets the preload on those bearings.
Marking the position, nut to pinion shaft & counting the nut's turns upon removal, helps take some of the reinstall guess-work out of it.
Slowly bringing the torque back up to spec, while checking bearing clearance, (side-to-side "wiggle" and rotational friction) helps you find your way back to the correct tightness.
Get it to loose, the nut looses torque, comes-off and the grears "crash" together. (self-distruction)
Get it to tight, the pinion bearings burn-up.
In real world, it is better to have it a little tight, then a little loose.
What I usually find, is that the reinstall torque goes back to the listed factory spec. and then I put another 5 ftlbs on top of that, and it's good.
PostPosted: Tue May 25, 2010 9:55 am
thank you doc that the info I was looking for
keep on roddin'
