It is currently Sun May 24, 2026 11:03 am
PostPosted: Wed May 19, 2010 5:44 pm
Hello every one, I have hear about the tubes that goes arround the spark plug!!
what is the function of this tubes?
do I have to replace some sore of a gasket or seal on this tubes if I decide to change the spark plugs on my engine??
please help, before I decide to take on this task..
one more thing,,were cna I get the Trunk lid/door Seal? the rubber thing that goes arround the lip of the trunk compartment.
thanks very much.
salud.
El Guapo From Santo Poco
PostPosted: Wed May 19, 2010 6:03 pm
Saludos! There is an aluminum tube surrounding each spark plug, to close the space between the cylinder head casting's outer wall and its inner wall. Each spark plug tube has a rubber O-ring that should be replaced because they cook, harden, and crack, then they don't seal any more. Also, remove the metal ring washers from the new spark plugs before you install them. Tune-up parts and technique suggestions in this thread.
PostPosted: Thu May 20, 2010 9:00 am
Saludos Señor Dan.
Remove the metal ring washer from the spark plug??
is that a recomendation, or a spec from DODGE?
I noticed my engine is leaking hell of oil when at hig way speeds, ,,is this due to this aluminum tube seal been cooked allready, or this tube and O ring never touch the Oil?
it sounds complicated to me, sorry.
my engine is running like a champ, on the last two days I have pushed the engine to 80miles per hour,,and it seems to old it really strong...if it was't for the oil leaks and the freeze plugs that are giving up..
thanks.
salud.
PostPosted: Thu May 20, 2010 9:45 am
Both.
When the tube seals fail to seal, oil will leak. There are other places oil can leak, too, such as the oil pressure sensor and numerous other gaskets and seals.
It's not. It's really easy.
PostPosted: Thu May 20, 2010 11:10 am
ha,ha, Thanks, I was referring to the Alumminum tubess,,that did sound confussing to me, but it is all clear now, I cna see the Light shinning through.
I just got my Cherry picker and engine stand from Craig List,,so the slant six engine is comming out real soon for a reseal, and re_bunch of stuff, I like to know what the heck I'm driving,,he,he.
Thanks Señor Dan.
salud.
