It is currently Thu Nov 26, 2026 4:40 pm
 Post subject: Aussie Intake Questions
PostPosted: Thu Jul 10, 2003 8:55 am
There are a couple of Aussie intakes up on ebay that look interesting, they are manufactured by a company called LYNX, one appears to be 3 X with Constant Depression S.U> (Skinners Union) side draught carbs (I am guessing 3 1 bbls??) and the other a 2 X with Constant Depression Zenith side draught carbs (look like these are 2 bbls)...Anyone ever run either of these or know anything about them. Can US side draft carbs be "off the shelf" adapted to these intakes or would it take a bit of machining to get an adapter?
I have been considering building a second engine/tranny combo for my challenger and wanted to do something a little different and this might be the ticket. or if I could adapt 2 bbl carbs to the 3X and find a six speed transmission I might try making a 6-6-6 Demon.
Here are the links if anyone is interested in seeing the intakes.
2 X
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=34198
3 X
 Post subject: Shipping kills....
PostPosted: Thu Jul 10, 2003 9:49 am
Unfortunately Australia is the place you can't get to from here. I just shipped a late model aluminum intake and carby to Oz. The guy paid $15 for the intake and Holley, shipping from Oregon was $71 by boat (2-3 month wait), or $130 by Air (2 week ship date...).
doc should have more experience with these setups...
PostPosted: Fri Jul 11, 2003 1:11 am
the su carbs are a really good performance carb for the slant, if you use the 1 3/4"(volvo's morriss etc)or better still are the 2"(jag's).both will bolt up to the lunx manifold.also the jap type side draugh will also(don't know what these are like for performance though.)the exchange rate for $$ make it a reasonable buy from the us side.oz $ is about 68 us cents.some guy's also use su manifolds for the basis of triple throttle bodied fuel injection as the bolt pattern on the manifold is easily adapterble to jap throttle bodies.
 Post subject: aussie intakes
PostPosted: Fri Jul 11, 2003 5:28 am
You'd definitely want more than a stock cam with the triple. There are also a fuel distribution / velocity issues with a triple vs. a double. Note that a triple Weber DCOE Clifford intake is different because it has 1 barrel feeding each runner.
See 4th and 5th entries in this thread for more on this:
http://www.slantsix.com/UBB/Forum11/HTML/000144.html
---Red
PostPosted: Sun Jul 13, 2003 7:13 pm
My main concern with using the Oz's carbs is finding rebuilt kits here in the US. But looking at the info from Red's post I am wondering if it would even be possible to get a smooth running motor with that setup. Plus I think I like the idea of putting 3 X 2 BBL on a slant with a 6 speed transmission behind it. Maybe it is just a pipe dream and more concept than reality to think I could put together the combination. But the idea of driving around in a 666 Demon :twisted: was appealling to me, especially to take the kids trick-r-treating on Halloween :wink: .
PostPosted: Tue Jul 15, 2003 8:06 am
I like those ideas too - go for it!!
PostPosted: Tue Jul 15, 2003 12:44 pm
The balance tube that runs across the Lynx triple SU manifold eliminates most of the problems that were discussed in that article. Notice this is in stark contrast to the Clifford triple Weber manifold which doesn't have such a tube.
PostPosted: Tue Jul 15, 2003 6:58 pm
Gee, reading that thread it's a wonder that all those E-type Jags with their triple SU 3.8 liter (232 ci) engines run at all......I guess that's why they only have 265 hp. :( And those Aston Martins.....how did Jim Bond ever escape?
I would venture that few of you have had the chance to try triple SU's or Stromberg CD's on anything, so let me toss in my two pennies taken from my experience with three Jags and a Healey, all with triple SU's. The concern expressed over "uneven intake pulses" in the other thread is an non-issue in practice. Taken a step further, you might guess that an individual runner system with side draft DCOE Webers would not run well either because the intake pulses are "uneven".
You do need a balance tube between the carbs for two reasons. One, it helps idle. Getting three carbs perfectly synched is tough. A balance passage helps reduce that sensitivity. Second, it helps provide a smoother manifold vacuum signal. You will experience a pulsing vacuum at idle if the inlets are not connected in some way. Once past idle the balance passage is usually too small to make any difference. It looks as though these manifolds have something cast in place.
Jags, Aston Martins, big Healeys all ran well with triple SU's. It was the factory's normal approach to more power and it worked very well.
BTW, rebuild kits are easily had in the US. SU's are dead simple to rebuild since you have no power valves or accelerator pumps to deal with. The one thing you do want to ensure is that the carb's moving parts are not worn and that the throttle shaft has a good fit to the body with no air leaks.
Jack Collins
66 Mustang 250 EFI
Lotus Seven Replica (Under Construction)
<img border="2" src="http://fordsix.com/locost/locostsig.jpg" width="275" height="118" >
PostPosted: Tue Jul 15, 2003 11:23 pm
Thanks for the insights on SUs Jack,
The only time I worked on SU carbs was waayyy back when my older brother had a MG with two SUs. Keeping the idle good was a chore but the engine always ran well at speed.
 Post subject: triple su Aussie intake
PostPosted: Wed Jul 16, 2003 5:27 am
mustangsix...
I don't claim to be an authority on on either SU carbs or triple carbs on inline 6 engines, not having had first-hand experience with either. Was just passing on some info that I ran into when doing an extensive search of Volvo, MG and Mini Cooper and Brit sportscar websites r.e. those subjects. The concensus there seemed to be that although the triples worked (presumably, they never would've seen production had the problems been too severe) that the doubles were a more satisfactory design. If you have experience to the contrary, I stand corrected.
Another impression I got from the above sites, and from some books I've read about SUs, is that needle taper selection is the real "black art" when trying to get SUs "dialed in".
---Red
PostPosted: Wed Jul 16, 2003 10:44 am
So here are some theoretical questions, since I have no knowledge of side draught carbs and am assuming that these SU carbs are single barrel and not 2 barrel carbs, and I really would like to see a 6 pack type setup:
Since the intake has the balance tube between all three carb ports, could someone machine an L shaped adapter for each of the 3 ports to place Carter or Holley 2 bbl carbs on this intake? understanding that said person would have to be a capable machnist (which I am not). Would the L shape and additional runner length affect the air/gas flow and create other issues?
Would this "six barrel" setup be just to much carb for even a highly modified slant motor? Or could the jets be "adjusted" down in the two barrel carbs to make this setup work?
PostPosted: Wed Jul 16, 2003 5:25 pm
I'm not the world's foremost expert on SU's either, Red. I've just been lucky enough to own some wonderful cars and have had some first hand experience rebuilding and tuning. :D
The most common arrangement was the twin sidedraft, but that was probably more a cost consideration than anything. In later years it was an emissions consideration as well.
Needle selection is indeed a "black art", Red. There are (or were) a lot of tuners who carefully selected the tapers to tune the fuel delivery curve. The guys who did this for high performance English cars spent hours on the dyno and track to make sure that as the load changed, the needle was exactly right, then came back and turned needles to exacting specs on a jewelers lathe. But, it can be a lot simpler than that, just like swapping jets in a Holley, easier in fact.
Needles are still available new in various sizes and tapers to give you richer or leaner fuel curves. By simply removing the slide and screwing in a new needle you can adjust the curve. The stock needles are usually a little lean, in my experience, but you can adjust the mixture by either raising or lowering the needle or raising or lowering the jet. Sounds complex, but it's very simple. Ask any Harley mechanic.
One of the great things about using constant velocity carbs is that unlike a typical carb, they are somewhat self adjusting for capacity. Only as much air as the engine can use is actually allowed to pass, so overcarbing with SU's is not so common. You could as easily use a pair of H6's (1.75" throttle) as H8's (2" throttle) and still get good results on a 200-250 cube six.
As far as using six SU's, I'm not sure that would be a worthwhile exercise. It would look pretty neat, but by the time you bought and modified a manifold, did all the custom machining, bought six carbs and all the attendant fittings, you would probably find it cheaper to use triple DCOE Webers, which would give you one throttle per cylinder as well.
As a side note, in my sig you'll notice the Lotus replica I'm building with a Ford inline six. I'm fabricating tubing manifolds to utilize triple Stromberg CD175 constant velocity sidedrafts on this engine. Click the sig picture for a little more info.
Jack Collins
66 Mustang 250 EFI
 Post subject: aussie su intakes
PostPosted: Wed Jul 16, 2003 7:12 pm
mustangsix...
Thanks for sharing the info..."booklearning" is never near enough: Always a wise move to listen to the guy with the greasy hands.
What a cool project you've got going!
"In hindsight, I would have changed several aspects of construction and in any subsequent buildup, I'll take advantage of lessons learned"
Now ain't THAT always the way it goes!!!!
---Red
PostPosted: Fri Jul 18, 2003 8:31 pm
Thanks for the complements. :D
These little Locosts are very fast with almost any engine you put in it. I just thought an inline six would be neat. Now I'm just waiting for one of the Slant Six tribe to jump in and build one!
Do a few calculations and you'd be surprised how fast a 1200lb car can be with even a stock 225 under the bonnet.
<img src="http://fordsix.com/locost/locostthreequarter2.jpg"width=400>
Jack Collins
66 Mustang 250 EFI
PostPosted: Mon Jul 21, 2003 9:34 pm
is that a kit car or something you're building from scratch???
Forget the flowmasters...here come the good ol' GLASSPACKS!!!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 9 guests
