It is currently Fri Nov 20, 2026 6:34 am
 Post subject: a 904
PostPosted: Mon May 24, 2010 8:40 am
I am wondering if anyone can tell me if an A904 from a 77 will work in an 78 ? Is the only differance the Lock-up Converter , or will I have to buy a Non Lock -up for it . Thank You Jim
PostPosted: Mon May 24, 2010 9:24 am
Converters are different between the two.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue May 25, 2010 5:30 am
Just use the converter that goes with the trans. Lockup converter with lock up trans, or a non lock up converter with a non lock up trans.
PostPosted: Tue May 25, 2010 4:31 pm
Not to steal your question but this is relevant... If they started with the lock up converters in 78, and my car is a 78 model without a lock up, would that be only because it was built in february of 77? I also own a 79 aspen (parts car) that has a lock up converter, would there be a problem with swapping the converters or would it require the whole different tranny? If so, why?
PostPosted: Tue May 25, 2010 4:54 pm
You have to swap the complete transmission.
There are a number of differences between the L-up & non L-up trannys, besides the converter, the input shaft spline count , oil feed holes and valve body are different.
