It is currently Wed Nov 25, 2026 9:20 am
PostPosted: Sat Jul 12, 2003 8:24 am
Hi
Thanks to fellow listers for the advice on troubleshooting my fast idle problems.
I diconnected the throttle cable, put er in drive and she still rolls forward-so its not the throttle cable
I disconnected the kickdown linkage spring and put er in drive and she still rolled forward so it is not the kickdown linkage.
I tried fiddling with the mixture screws and the curb idle adjust for a good 30 minutes and it seems very easy to get the car to idle nicely, even with the curb idle screw set so it is not contacting anything.
A reply to my earlier post mentioned the possibility of an incorrectly set butterfly valve. I had the carb rebuilt by a specialty shop here in town and it seems to be set spot on, the car runs very nicely throught the range of the throttle. I dont know what the position of the butterfly should be but I havent hooked up the choke yet and the butterfly is straight up and down vertically (no restriction of airflow) as the car sits at idle when it is warmed up.
So, based on the responses I recieved for my earlier post on this subject, the only thing I cant rule out is the butterfly, what is it supposed to look like? Any other ideas?
Advice is appreciated as always
-DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 8:34 am
What is the idle speed? (RPM)
The thing to check on the throttle blades is if they line-up and seat completly in the throttle bores.
With the carb off this is easy to check by holding the carb up to a brite light and looking in from the other side to see how much light is passing around the edge of the blades.
The blades need to be centered so they will shut-off all the airflow at idle, the lets the idle circuit "bleed-in' the air / fuel to control the idle mixture.
With the carb installed all you can do is look closely at the blade edges to see if there are any gaps or rub marks on the throttle bore(s), this would indicate that the blade(s) may not be centered well.
Do the blades have small holes in them?
PostPosted: Sat Jul 12, 2003 8:41 am
Another thing to check is the base timing setting. A too-advanced timing setting can make the engine idle on a ridiculously small amount of air, such that you really can't close the throttle plates enough. Just the slightest whiff of air past them can keep it running. That said, most automatics will creep forward at idle unless there's a hill. My truck is pretty bad about it, and there's nothing wrong with the idle speed. The torque converter is just that tight.
PostPosted: Sat Jul 12, 2003 8:43 am
Oh
You are talking about the blades not the butterfly on the top for the choke.
That changes things as far as troubleshooting goes
The carb is on the motor now
I dont remember if the blades have holes or not
I am going to try and see what I can do from topside before removing the carb from the motor.
Anything else you can think of before I pull the carb.
Like I said, the shop I used is very good and they bench test each rebuild to make sure it is set up right. Of course this doesnt rule out the issues with the butterflies as everyone screws up, even the best of us :D
DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 8:44 am
Honestly, I'd just remove the carb. It's so easy on these motors, and you end up with an unobstructed view of everything. Still might want to check the timing though.
PostPosted: Sat Jul 12, 2003 8:52 am
So I think my troubleshooting sequence will be
Remove carb and check for full closure and seal of butterflies at o throttle opening. If this is fine, next retard timing a bit and redial in the carb
If these things dont work, Ill just live with it. It isnt too bad but I did such a good job and the car is running so sweetly that I want to do the whole shooting match right before I can step back and pat myself on the back :roll:
-DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 8:54 am
Oh crap I forgot
What impact does holes in the throttle blades have?
It seems like if I do have holes and they let air through I am going to have fast idle issue. If my throttle blades do have holes, should I plug them with something? If so what? High temp rtv? JB Weld?
Thanks
DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 8:59 am
You are saying the idle is too high. This is being very subjective. One thing no one, including myself, has asked is : What RPM is the idle, both in neutral and in drive. Some cars will move in drive as low as 600 rpm. There is nothing to adjust to cure this. What you have may be normal.
PostPosted: Sat Jul 12, 2003 9:05 am
Yeah, you're right. One of us should have asked what the idle rpm is. That's basically what I meant when I was talking about my truck creeping in gear, I just didn't say it so well.
PostPosted: Sat Jul 12, 2003 10:24 am
I checked and the butterflies have no holes and seem to be seating properly in their bores.
Only thing left is the timing but you know the car runs so nicely and I just got back from a trip cross town on some errands and the creeping forward is not bad at all. It seems intermittent too, that is sometimes it really isnt so bad.
I think I am going to save my energy for fixing the wiper linkage bar which has decided to remove itself. I found the replacement bushings and now I have to figure out how to get the bar back onto the wiper pivot ends. Gonna have to dial in some elbow grease
-DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 10:31 am
Yeah, I think you made the right decision. That was sounding increasingly like a non-problem. On the wiper bushings, there's one tool I can recommend that I've found to be a big help. It's a pair of needle nose pliers, but the grip jaws are curved about 70 degrees. The handles are pretty long compared to most needle nose pliers. I can't remember where I bought them, but it's possible a regular chain autoparts store will have them. If not, any tool store should. I've found them unbelievably useful for everything from grabbing hard-to-get-to wiper linkages under dashboards to pulling stuck sparkplug boots off w/o destroying the wires. The angle the grip jaws have just happens to be right for many automotive jobs. I don't remember what they cost, but it wasn't anything bad. Maybe around $10.
PostPosted: Sat Jul 12, 2003 10:46 am
I got the bushings in by heating the rod and greasing the bushing on the outside. Then I worked my way around the lip with a needlenose vice grip to seat the bushing in the hole.
Now I have to figure out how to get the pivot end to seat into the bushing. It is hard because you cant see up in that channel and there is little clearance to work with. I plan to grease the inside of the bushing and then lever it on with a long pry bar or screwdriver. Dont know how much force this will take. I think I know the pliars you are referring to, I will seek some out if I need to.
I have to say, the wipers on this car are pathetic. The linkage is really kind of crappy and the motor is noisy as hell and the action jerky.
Hey then again, it aint a volare for nothing. There is a reason lots of people make fun of these cars but since I super sixed mine it is almost as fun to drive as my 70 big block road runner. (ok not quite :twisted: )
The volare really needs a 4 speed and some better rear end gears and I am sure it would be a terror around town
-DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 11:20 am
Yeah, I don't know how long chrysler used those retarded plastic wiper bushings. My '74 duster has them, my '78 truck has them, and I think my '86 ramcharger has them. However, my '70 valiant has brass bushings. I'm pretty sure they've never been removed, and they work fine. There's a guy on moparts.com who specializes in chrysler wiper bushings and linkage, I think he goes by the name Jules the Wiperman. He's a really nice guy, and will give good advice if you ask. He told me that you can swap to the earlier brass stuff on A bodies if you also swap wiper motors. I found out the hard way when my original 1970 wiper motor finally died that the 1974 motor won't directly interchange. Nothing different electrically or in how it mounts, but the size of the square on the end of the shaft is different. So, the linkage in the '70 car wouldn't hook to the motor shaft from the '74, even though the motor would bolt and hook up otherwise. I'd imagine your volare motor is the same as the later A body motor. If you were willing to go to the trouble, you could get the linkage and motor from an older A body and swap the whole thing. Barring something unusual, that would be the last time you would probably ever need to deal with the wiper bushings again. This proves once again that even chrysler started going cheap in the 70's. I had no idea such a change had been made to A bodies until I stumbled on it myself.
 Post subject: Critical info needed...
PostPosted: Sat Jul 12, 2003 12:02 pm
The F-body was the 'improvement' of the A-body, in doing so they changed the cowl and the wiper linkage to match the new firewall shape.
According to my 1976 Parts Catalog, the motors, linkage, and armature are all different for the Volare from any A-body. I think the only interchanges are the bushings, and the wiper arms and blades. If you have a good lead on that I'd ask the expert on those kind of swaps. I feel for you, the Volare's underdash is not as easy to work under as the A-body (and those are still kinda tight....).
A 'jerky' action is mostly due to bad bushings or bad blades dragging, if the wiper motor is not sounding healthy, it'd be good to replace it before it leaves you blind in the rain.
PostPosted: Sat Jul 12, 2003 12:21 pm
Oh, I didn't know they changed the firewall on those cars. In hindsight, it might have been better to continue the A body. Oh well, I guess I'm just used to A bodies.
