It is currently Wed Nov 25, 2026 1:26 pm
PostPosted: Sat Jul 12, 2003 3:12 pm
Ok
Id like to meet the sadist who designed the linkage system for the 76 f body.
How in the heck is a big guy like me supposed to get up in there with enough force to pop the bushing over the flair in the pivot end.
I have cut my hand to ribbons on the sharp edge of the cowling that hangs down and am about 2 steps away from taking an angle grinder and removing enough metal to get in there and get the job done.
Please please-anyone with a good trick for intalling the linkage rod please let me know how you did it
Many thanks
DW
Dr Wheelie
PostPosted: Sat Jul 12, 2003 9:39 pm
What's a 76 F body? No such beast in my 1976 service manual.
Which link you working on? Between motor and wiper or the other one between the 2 wipers?
Service manual says to use channel lock pliers to snap the bushing and link over the stud.
Some cars you need to remove the AC duct to get better access.
Some may help to stop the wipers in mid position.
PostPosted: Sat Jul 12, 2003 9:54 pm
Wiper link section is in the Electrical Service manual on page 8-165 for 1976 'H & N' models (F-bodies).
Chrysler's proceedure is the absolute reverse of A-body logic....
Pull the cowl screen and wiper arms, remove nuts for the wiper pivots, drop the whole assembly, replace bushings, reassemble, reseal , and put everything back into place, torque wiper mounting nuts to 125 inch pounds....
"Personally I wish the A-body had lasted until 1978..."
PostPosted: Sun Jul 13, 2003 7:18 am
Thanks for the info
I am talking about the link between the 2 wiper arms.
Dont know about the A body but in the f body you have no access from beneath the dash because the wiper drive gear lives in a narrow channel that has sheet metal about 2 inches beneath the bottom of the wiper pivots.
I have the official 76 manual and I just realized that the wipers are in a separate suppliment, rats. One weird thing is that I also have a chiltons manual and it has nothing about this service. Seems weird since this seems like an important and common proceedure.
So it seems like the electrical manual I dont have requires loosening the wiper arms. When you say "drop" the wiper pivots do you mean take them loose from their mounting and lower them inside the channel as to allow better access?
As much info as you can provide from the manual would be appreciated since I obviously cant just go out and buy one today to help get the job done
-DW
Dr Wheelie
PostPosted: Sun Jul 13, 2003 9:08 am
Drive Link and Crank Assembly, Connecting Link and Pivots
1)disconnect the battery ground cable
2)Remove cowl top plastic screen to gain access to the wiper assembly
3)remove arm blade assemblies
4)Remove drive crank from the wiper motor by removing the attaching nut with a 3/8" wrench
5)Remove pivot mounting nut and washer
6)Remove linkage assembly from the plenum chamber
7)replace defective parts
8)Position the linkage assembly back in the plenum chamber
9)Install mounting nuts and washers, torque to 125 inch pounds (about 10 ft/lbs)
10)index the flats on the drive crank to mate with the flats on the motor shaft. Tighten the attaching nut to 95 inch pounds.
11)reconnect battery ground cable
12)operate wiper linkage to verify correct function. Reinstall wiper blade assemblies. Verify correct operation of the wiper system.
13)Replace the cowl top plastic screen.
14)connect the washer hose if necessary...
good luck,
PostPosted: Sun Jul 13, 2003 9:36 am
Guess I know what Ill be doing this afternoon
Just hope it doesnt rain!
thanks
DW
Dr Wheelie
PostPosted: Wed Jul 16, 2003 7:11 am
This sound similar to what I did for my truck. Be sure to re-aim the washer nozzles when you're done. Mine were missing the holes in the grate. I thought the motor had gone bad.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 8 guests
