It is currently Thu Jan 30, 2025 6:52 pm
 Post subject: 904 small parts source?
PostPosted: Fri Jun 04, 2010 1:28 pm
So I am rebuilding my first 904. I bought a "complete transmission rebuild kit" off of eBay from "Portland Tranny". Turns out that the "complete rebuild kit" doesn't include the thrust washers.
The front/#1 thrust washer in the tranny is dead in the middle of spec at .062 inches thick. The #2 thrust washer is worn beyond spec at .058 inches thick. Service tolerance for both washers is .061-.063 inches as per the 1983 FSM.
So, where can I buy JUST the #2 thrust washer? :?
PostPosted: Fri Jun 04, 2010 2:25 pm
6 Pack Dart
Reed send me your address via PM, as I have one. :shock: :lol:
Richard
PostPosted: Fri Jun 04, 2010 3:36 pm
Thanks Richard, but I managed to locate one locally. Dealer doesn't carry them, Aamco doesn't carry them, two local shops didn't carry them, one placed wanted $30 to order it for Monday, a website wanted $.50 per washer but $11 shipping, etc....
BUT! I found a business, Casey's Trans-Plant, that is locally owned, had one in stock, and they GAVE IT TO ME!!!! :shock: :D
So, form now on, my transmission needs will be met by:
http://caseystransplant.com/
PostPosted: Fri Jun 04, 2010 5:58 pm
Hi Reed. Take a look at the text following these kits, while your trannie is in pieces, you can do some corrections to improve lubrication and choose the lock-up speed. I am sure your local guy can get them for you if you don't order them on eBay yourself. I ordered from Oregon Performance Transmission, and they gave real good service when asked questions and shipped right away.
This is the correction kit, or maybe this larger one.
Olaf
Aspenized
PostPosted: Fri Jun 04, 2010 7:57 pm
Thanks Olaf. I ordered all my parts from Oregon transmission, including those shift correction kits.
Right now, I have determined that my clutch packs and thrust washers are in good condition I am currently looking over the valve body and double checking all the modifications I did when i installed a Transgo Shift Kit previously.
I hate transmission fluid.
Users browsing this forum: Semrush [Bot] and 2 guests
