It is currently Wed Nov 25, 2026 11:02 am
 Post subject: Timing set
PostPosted: Sun Jul 13, 2003 12:14 am
I was just talking to a guy with a 318 and mentioned the low oil pressure problems in the Dart, and he suggested that it could possibly be because of the stock timing set having nylon teeth that could be snapping and getting sucked up against the pickup screen, clogging it up.
If the stock set does have nylon teeth, and given the age of the engine, you guys think this is likely?
If so, I'm going to push them into ordering a steel dual roller set from JP Performance. How difficult is it to degree in the cam and set the cam timing just right when installing a new timing set?
How about the overall procedure? Pretty simple?
PostPosted: Sun Jul 13, 2003 1:31 am
Timing cover assembling is the only difficult job there.
Joug
Sorry, my english is not very good
PostPosted: Sun Jul 13, 2003 8:52 am
Degreeing in the cam isn't hard, you'll have to follow the directions in the package if you purchase a degree wheel, the fun part is drilling the set and bushing it (kit or lead shot) to make the centerline 'correct'...
PostPosted: Sun Jul 13, 2003 10:30 am
Yeah that's what I don't understand at all is the centerline and the part about drilling and using bushings. What's the ideal degree to have a factory cam set at?
Is there a way to do it without a degree wheel? I don't think her dad has one :?
PostPosted: Sun Jul 13, 2003 5:37 pm
I don't think it is neccessary to spent the money for the double roller timing set, on a stock engine. Just get a stock replacement set with a steel cam gear from a parts store. Should be about $20-$30, compared to $80-$90.
PostPosted: Sun Jul 13, 2003 5:42 pm
Ahhh but she won't be stock for long :twisted:
PostPosted: Tue Jul 15, 2003 8:05 am
Here's a secret. I have a stock replacement link-belt type timing set in my '64 Dart. It is the all-metal cast type, and I've only seen that type on '60s Slants I've disassembled. 40+k miles, 14 sec 1/4s and lots of racing...
It was a little stretched when I had the oil pan off last year, but still fine. I'll eventually put a roller one in...
PostPosted: Tue Jul 15, 2003 9:24 am
I'm with Lou. The only slant motor I have with the double roller chain, is the one with the mopar 528 cam. Every other slant motor I have built has had the "stock" replacement timing set, with a all metal cam gear. Never had a problem.
I'm Charrlies _S wife. Enjoy much of what he enjoys. Love watching him brag about old times and watching him drag race the cuda . . :)
PostPosted: Tue Jul 15, 2003 9:27 am
oops, Wife forgot to log off
