It is currently Sat Jun 20, 2026 2:55 am
 Post subject: 1966 lift questions
PostPosted: Thu Jun 10, 2010 12:19 pm
i want to raise my 66 dart front and rear and would like to know
the parts or adjustments i need to do this.
i like that high gasser look but not to high
maybe air shocks for back?
thank you for reading this
wayne
PostPosted: Thu Jun 10, 2010 6:04 pm
add a leaf /rearc rear springs....if air shocks used , need to reinforce mount....tighten torsion bar in front , get realinement done
 Post subject: lift kit
PostPosted: Thu Jun 10, 2010 6:44 pm
I am 61 and have never seen anything like this ought to lift as high as you want
regards max
http://cgi.ebay.com/ebaymotors/5532-MOP ... 3c9251[url]
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
 Post subject: Re: 1966 lift questions
PostPosted: Fri Jun 11, 2010 8:06 am
wayne
A traditional gasser would probably have an A100 van solid axle under the front on a fabricated frame. You can also raise a Dart by adjusting the torsion bar bolts on the lower control arms, although the look isn't quite the same. For the rear, use Super Stock springs, and if that's not enough lift, longer shackles. The stock upper shock mounts are not strong enough to take air shocks.
By 1966, you'd often see the front and rear suspension moved forward substantially. See this link for the original example. It also shows the solid axle conversion.
http://www.1962to1965mopar.ornocar.com/landys64.html
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
