It is currently Mon Jun 22, 2026 8:33 am
 Post subject: Engine ID frustration
PostPosted: Fri Jun 11, 2010 1:36 pm
Haven't been able to find my code. Looked from above and below. The engine is clean, so it shouldn't be covered with grease. Do I have to remove the coil to see it?
There are five freeze plugs, so I know it's not original to the car.
I spent quite a while looking for a picture of an engine showing the code, but the only one I found is this one and it's hard to tell exactly where it is.
Dan said in another post: "The numbers needed for engine ID are stamped on a pad facing the sky at the top of the block below the frontmost spark plug, inboard of the alternator lower support/coil bracket."
Below the second freeze plug it has 530-8
Below the third and fourth is a little plate that has 1188: held on with screws. What looks like AAWJ is embossed below that.
Anybody know what that means?
On the passenger side between the fuel pump and oil pan, I found what looks like info about what shift the employees were on when the block was cast.
PostPosted: Fri Jun 11, 2010 1:55 pm
6 Pack Dart
See this post it has a picture.
http://www.slantsix.org/forum/viewtopic.php?t=40010
PostPosted: Fri Jun 11, 2010 2:19 pm
Site Admin
And another photo of where the stamped number is.
CJ
