It is currently Fri Jun 05, 2026 8:06 am
 Post subject: Carb Spacer
PostPosted: Sat Jun 12, 2010 9:26 am
The Walker rebuild kit for my Holley 1920 carb came with the typical carburetor-to-manifold gasket, but also included a thicker phenolic type spacer.
I didn't install the thick spacer and the car runs just fine.
Is there a good reason to install this spacer?
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Sat Jun 12, 2010 10:28 am
Yes, less heat soak....and fuel bowling in the carb after shut off. Start ups are much quicker.
PostPosted: Sat Jun 12, 2010 12:02 pm
cool...I'll stick it on there.
I'm guessing there will be some ever-so-slight adjustments needed in the linkage?
Is the thin gasket still needed in addition to the spacer?
PostPosted: Sat Jun 12, 2010 10:23 pm
Yes on the gasket, and maybe on the kick down.
PostPosted: Sat Jun 12, 2010 11:08 pm
I guess I may be lucky...but my slant starts up blazingly fast when it's thoroughly warmed up. It doesn't even seem to turn over once and it's running...I almost can't turn and release the ingnition switch fast enough.
I was always told growing up that an engine in proper tune should jump to life like that, but I've read a lot on this forum about these slants being a bit hard to start when they're warmed up.
Again...I guess I may just be lucky.
 Post subject: Carb spacer.
PostPosted: Sun Jun 13, 2010 2:40 am
Mine always starts straight away doesnt get a full revolution and shes running,and starts nearly as good cold and after sitting for a week.49200 miles on the clock,electronic ignition,single bbl carb.goes hard. :D
Another AP5 valiant still going strong.
 Post subject: Re: Carb spacer.
PostPosted: Sun Jun 13, 2010 9:51 am
That's cool.
I always knew when I had my stock Model A Ford in good tune....because I could just ever so slightly tug on the crank and it would fire right up.
PostPosted: Sun Jun 13, 2010 11:35 am
That's the way mine starts up. A portion of a turn on the starter and bang! It is running....If your happy with it don't change it.
Many folks aren't as fortunate.
