It is currently Mon May 18, 2026 3:53 am
 Post subject: What is this??
PostPosted: Thu Jun 17, 2010 6:34 pm
In the bottom left hand corner of this picture, there's a can type device that resembles one similar to the one in our 72 Duster, but we have no idea what it is. It appears to be a part of an emission control system, but we're not certain. There are vacuum hoses running to the pvc and one into the carburator. Any ideas?
PostPosted: Thu Jun 17, 2010 7:08 pm
Hello,
If the item with the arrow to it is what you mean,it looks like the Dryer/Receiver for your aircon.It appears to have a little sight glass on the top? If so,that is what it is.
If you do not mean that,could you be a little more specific with a close up pic?
Here is an aircon diagram. The dryer/receiver is marked.
regards,Rod :D
 Post subject: Nope...
PostPosted: Thu Jun 17, 2010 7:20 pm
If it runs to the PVC, carb fuel bowl, and fuel tank vent...it is the charcoal cannister to divert/hold excess fuel fumes/emissions...it isn't a bad thing, but does need to have the charcoal filter replaced if it's a few decades old.
PostPosted: Thu Jun 17, 2010 7:26 pm
We don't have A/C in our car, so it's probably not the same as the device in the picture. We just looked at it again, and it has the following labels for the different hoses going in and out of it in this order:
Dist. Vac
PCV
Fuel Tank
Carb Bowl
 Post subject: Re: Nope...
PostPosted: Thu Jun 17, 2010 7:27 pm
Ahh, thank you. So is this a necessary part then? I hadn't heard of it before today. Was it introduced in 72?
PostPosted: Thu Jun 17, 2010 7:39 pm
Dist. Vac
PCV
Fuel Tank
Carb Bowl
So,you are saying this picture is not of your car?
There is quite clearly an aircon compressor sitting there in plain view if it is yours.
regards,Rod :? :?
PostPosted: Thu Jun 17, 2010 8:24 pm
Dist. Vac
PCV
Fuel Tank
Carb Bowl
regards,Rod :? :?
No, that's not a picture of my car, I just tried to search for a picture with a similar device in it.
PostPosted: Fri Jun 18, 2010 5:16 am
Dist. Vac
PCV
Fuel Tank
Carb Bowl
regards,Rod :? :?
Thought I was going silly there for a while. :roll: I worry about early onset of Alzheimers.
regards, whats my name?
PostPosted: Fri Jun 18, 2010 8:55 am
Haha, no, it's all good. Thanks for the help. I searched the forums regarding the Charcoal Canister, and it looks like it's not something I should be removing.
I'm just looking for a way to clean up the engine bay a bit to make it a little more aesthetically pleasing.
PostPosted: Fri Jun 18, 2010 9:59 am
Keep it....
It provides a very useful function. It is great to have on hot days to reduce fuel vaporization and odor from under the hood.
Click on the red link below to see how I routed the hoses out of the way...when the first picture comes up, double click on it for full screen slide show mode.
PostPosted: Fri Jun 18, 2010 10:43 am
Oooh, that's pretty awesome! I think that's what I'll end up doing.
Where did you pick up that valve cover? It looks awesome!
PostPosted: Fri Jun 18, 2010 12:40 pm
Off eBay, they are quite common if do a search.
PostPosted: Fri Jun 18, 2010 1:22 pm
I see that. I think I'll order this right away! Thanks!
PostPosted: Fri Jun 18, 2010 1:46 pm
We all do our best not to spill any gas or oil. Sometimes it feels like, "what's the use?" A lot of little spills equals one big spill, maybe. :?
PostPosted: Tue Jun 22, 2010 10:36 am
Okay, so now that I've determined what the cannister is, it's quite clear that it is the culprit for putting little specks of charcoal into my carb. Any thoughts on where I could find a new one? It has these specifications:
Dist. Vac
PCV
Fuel Tank
Carb Bowl
Users browsing this forum: Google [Bot], morsim and 7 guests
