It is currently Mon Jun 08, 2026 3:10 pm
 Post subject: Not liking inline tube
PostPosted: Sat Jun 19, 2010 9:24 am
I recently purchased from Inline tube, a set of stainless brake lines that were meant to go between a standard master cylinder and a 1976 combo valve. The fitting sizes are 1/2" for the front line on both ends, and 9/16" on the rear line, both ends. The 'custom' lines arrived, and instead of a 9/16" fitting for the valve at the rear line was a 3/8 24 IFM fitting. That meant a trip to the nasty local parts store for an adapter. :P
Bleeding the brakes after a two-month overhaul of various things, the brakes leaked precisely where? At the parts store fitting. The fitting was to go from a 3/8 24 IFM to a 9/16" "master cylinder" port. Is there a different fitting I should be using, or should this seal? I expect better when shelling out half a day's pay for two brake lines. At least they could mention that this case might occur, and have a fitting available. :!:
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Sat Jun 19, 2010 10:59 am
try calling them , maybe they can mail you an adapter fitting or
mail the correct line with correct fittings.
PostPosted: Sat Jun 19, 2010 12:03 pm
That's the plan, first thing Monday. Patience is something I need to work on.
Spent all day trying to seal one fitting. Inline tube saved $.09 on their one-size-fits-all junk, so it's not a complete loss.
PostPosted: Sun Jun 20, 2010 12:29 pm
Stainless lines can be a pain to deal with, specially when old, they are hard and brittle if you need to cange them. For some input on alternatives, take a look here and here.
Olaf.
Aspenized
PostPosted: Mon Jun 21, 2010 9:50 am
Thanks Olaf. Next time, I'll definitely make my own lines.
I was finally able to get the 9/16" adapter to work (so far, so good), but it cost me all day Saturday until I took out the valve and put it in a vise.
I sent an email to Inline tube mentioning the recession, and the need for customer service. I haven't heard back from them.
On the plus side, my ability to be patient is getting a good workout. 8)
 Post subject: Hmmm...
PostPosted: Sat Jun 26, 2010 12:08 pm
I put Inline's stainless tubes in my D-150. Perfect fit. I suspect that the pattern piece they used for your application was incorrect--it happens. There customer service is good and I am sure they will fix you up...
Slanted D150
PostPosted: Sat Jun 26, 2010 4:01 pm
I think it was some kind of communication error. Or I was misinformed on the year of the valve. Their rep claims it shouldn't need an adapter. I got the adapter to seal, so I'm going to move forward on all the other things necessary to get on the road. Other than the fitting, the lines seem good.
Users browsing this forum: Bing [Bot] and 5 guests
