It is currently Tue Nov 17, 2026 5:34 am
 Post subject: Broken Studs
PostPosted: Sat Jun 19, 2010 10:07 am
Hi,
Trying to get two broken studs out of the cylinder head. I have tried welding a nut to the stud but for some reason all I can do is weld it to the cylinder head (what the hell?! I thought it wouldn't touch the cast iron?!). Im using steel nuts and a MIG welder and having no luck.
Also, the sodding left hooker drill bits i have got won't touch it.
Will some body offer some advice before I set fire to the car?
Thanks
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Sat Jun 19, 2010 11:08 am
I went through that awhile back and didn't want to take the head off. So.....
Get some good 135 degree drill bits. They cut much better.....I drilled mine starting with a small drill and worked up to the bigger sizes and finally used and easy out. On one hole, the top one near the fire wall I ended up breaking the easy out and had to take 3 small finish nails taping them in down the flukes and twisting them out with a screw driver. THen they bent so I took a small 1/4" socket and a die grinder and cut it so it had 3 points that matched the 3 flukes and with lots of JB-80 and Kriol twisted the entire mess out, bolt and broken easy out together.
Then I chased the threads with with a tap and that broke too.....it was real cold out....so I took my 1/4" socket that I modified and cut it some more to match the flukes on the end tap and turned it to back out. Keeping pressure against the tap helped to keep the points in the flukes and it came right out with a ratchet. The hole was saved and the threads.......but it took allot of patients and that is a long way to lean over across the end bay.
Some folks just remove the head and have a shop EDM the stud out.....
Which ever way you decide, don't give up! Install the new studs with locktite so they don't leak water and use lots of never sieze and brass nuts when you install the manifold. They will hold fine and come off with out snapping the studs.
PostPosted: Sat Jun 19, 2010 11:38 am
Thanks Ted,
I still don't know why the welding trick doesn't work. It seems almost fool proof, all I can do is weld the cast iron or get a crap weld with the stud thatjust falls apart. I think i've actually welded the stud to the head at the moment.
Stock 60 225
Right Hooker
PostPosted: Sat Jun 19, 2010 12:34 pm
Is the head still on the car? and is there water in the water jacket? Sometimes you will get steam coming around the threads.......when welding.
PostPosted: Sat Jun 19, 2010 1:35 pm
I dropped the coolant level enough that that shouldn't happen. I'm wondering if the Kroil had an effect (been kroiling it every night for a week). Maybe kroil also has mystical properties that allow cast iron to be welded . .
On this head, all the passages are through to the water jacket. Is that common on the early heads? What's the best thing to clean these out so that loctite bites?
I got a pilot drill through the stud and will have to order some taps. I will have to drill out the rest tomorrow when the battery's charged. I hate battery drills but they seem to be the only ones that run in reversefor reasonable money.
Instead of helicoils I'm going to try and make some threaded inserts. Best material?
Stock 60 225
Right Hooker
PostPosted: Sat Jun 19, 2010 2:01 pm
I am not sure what the best material is......but I had a super thin casting at one of the stud locations. Only 4 or 5 threads deep, so drilled it out bigger and tapped it for a heli-coil and used JB Weld. That did the trick and has lasted about 5 years now. No more leaks......or blown intake gaskets.
PostPosted: Sat Jun 19, 2010 2:42 pm
Sounds good, if helicoils and JB hold out on a thin casting should be good for me!
I also have a heat control valve problem to sort. I don't have one! All the springy bi-metallicy bits are missing. I think I'm getting to the bottom of the problems associated with my car . . .
Stock 60 225
Right Hooker
PostPosted: Sat Jun 19, 2010 3:30 pm
Hope springs eternal.
PostPosted: Sun Jun 20, 2010 7:01 am
Snag another one.....they a re pretty easy to adjust. I got mine dialed in perfectly by adjusting the spring.
PostPosted: Sun Jun 20, 2010 7:37 am
Good to hear they are easy to fit/adjust.
Unfortunately they aren't easy to get over here. Difficult to find volares/dusters/valiants sitting in scrap yards waiting for me to steal everything from them. Or possibly the entire car . . .
Dodge 50 vans had slants but most had the petrol engine swapped out long ago for a perkins diesel. I can also get 727 gearboxes but they come at a price! In the US, they were used on all manner of cars. Over here, we're talking about Rolls Royces, Bristols and Jensens - all prestige makes!
Stock 60 225
Right Hooker
PostPosted: Sun Jun 20, 2010 9:25 am
Have you tried car-part.com? You may be able to purchase the parts you need from the states, and have them shipped to you. I'm sure the shipping would be a little expensive, but it might be cheaper than purchasing parts off of a Rolls Royce!
Besides, the conversion from pounds to dollars is in your favor...
PostPosted: Mon Mar 14, 2011 4:16 pm
Car Model: 1965 Barracuda 'S' auto
Have faith. Very late but I was able to get mine clean and clear with a very small drill and a rather stout punch. I broke a stud flush with the head, drilled it out per exctractor directions and promptly broke the solid extractor in the frozen stud. I then drilled a very small hole next to the extractor chip all the way through to the water jacket. I then used increasingly larger drill bits until I was bouncing off the extractor chunk. I used the punch to tap the chunk out the back and then used a nail to peal the rest of the hollow stud away from the threads and finally got it with needle nose pliers, I saved the cast iron threads too! New stud, RTV, and antisieze on the special beveled castle nut I had to drill out and tap also as the stud was fused in that too. IF you got a fresh broken stud, heat that bad boy up as best as you can and then let it air cool, itll either soften the stud or expand it enough to contract to a small er size after it cools, hopefully breaking the seizure. If not, CENTERPUNCH the stud so you can get a good small drill bit started right down the center, keep getting bigger until you can either unscrew it with left handed drill bits or get it so thin you can take a very small punch, nailset or even a nail and pry/punch it off the threads and pull it out with needle nose pliers or push that out the back. Good luck. Prior to removing other studs, you can heat them, or whack them with a hammer to break the bonds. They have nut freeze now in a can that freezes the stud, contracting it and hopefully breaking the bond too. Never tried it but it looks like Duster brand canned air if you hold it upside down.
PostPosted: Tue Mar 15, 2011 6:14 am
I thought that Roll Royce / Bentley used slightly modified GM automatic transmissions, at least on cars built in the sixties & seventies.
PostPosted: Tue Mar 15, 2011 8:07 pm
Hi 60 Plymouth.
You should maybe include Scandinavia in your holiday plans, Sweden in particular, where Valiants were used as a police car for 15 years, and it was very popular in general. I have no statistics, but there should still be SL6 parts available in scrap yards, probably a lot more than in UK.
WPC Club of Norway (click flag for english version)
WPC Club Sweden Region (Länkar = links)
Mopar Club Denmark
Olaf.
Aspenized
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 8 guests
