It is currently Mon Jun 08, 2026 11:11 am
PostPosted: Sun Jun 20, 2010 4:05 pm
Is it necessary to swap the drum brake pedal assembly for the disc brake pedal assembly? I have all the donor parts, but was curious as to if this was necessary. Can the drum brake assembly be used or at the least, can I just swap the pedals? Just trying to avoid some unnecessary work if possible. This is a manual drum to power disc swap.
Thanks for any advice given.
PostPosted: Sun Jun 20, 2010 4:22 pm
You dont need to swap pedals. Just make sure the rod fits in the Master cylinder.
.Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Mon Jun 21, 2010 5:24 am
Thanks. I actually had it mocked up at one time before tearing it down and putting it on the back burner. Everything seemed to fit okay then. I thought that I remembered reading somewhere that there was a difference in the pedal geometry. I might be thinking about rod lengths between manual drums and manual disc. Hopefully I can get back to it this weekend. Thanks again.
PostPosted: Tue Jun 22, 2010 6:35 pm
Depends on which car you're working on. Some cars have a different brake pedal assembly for disc brakes vs. drum brakes.
PostPosted: Thu Jun 24, 2010 5:22 am
The car is a 68 Dart. I thought that there could be issues.
Thanks!
PostPosted: Thu Jun 24, 2010 7:47 am
Check the Master Parts book to be sure but I think a '68 Dart uses the same pedal for disc or drum. I know that I've worked on light trucks and C body cars that had different pedal assemblies. Sometimes the pedal assembly is the same but there is a second hole for the pushrod so the lever ratio can change.
Some A body cars used a complex assembly for the linkage on power brake cars. That whole linkage can be removed and replaced with a simple manual disc brake arrangement.
