It is currently Mon May 11, 2026 7:40 am
 Post subject: Odd spark issue
PostPosted: Thu Jun 24, 2010 7:02 am
The S6 that is in my '80 D100, skips like a dead miss if the spark plug wires are pushed all the way on like they are supposed to be, but smooths out if I pull them back from the plug just a bit. I guess it is making the spark jump and get hotter maybe? Anybody run into this before?
IIRC it has Autolite 64's in it. I have swapped distributors, cap, rotor, plug wires, coils, ignition modules, and wiring harnesses trying to find this skip. I have adjusted the valves to spec (and double and triple checked it), and done a compression check, which came up good (~150psi all cylinders).
It just so happened that one day I set all the plug wires slightly loose on the plugs so I could start it up and pull the off one by one and find what cylinders weren't firing properly, and voila, the miss was gone.
The engine looks to be a fresh rebuild, but I have no idea what it is or was originally. It has adj rockers, it is the newer head I think (spark plugs are not recessed in tubes), has a 2bbl intake. Block is well grounded to the body.
Anybody ever run into this before? Or have any insight?
Rob M
'80 D100 SWB stepside, S6 4-spd OD
PostPosted: Thu Jun 24, 2010 9:47 am
Various add-on gizmos over the years used an extra gap to help with marginal systems. I'd triple check the coil polarity first.
PostPosted: Thu Jun 24, 2010 11:05 pm
Alright, I'll check that. IIRC it's off a turbo dodge, and I checked it w/ a coil checker and it was outputting 35-40k volts.
Rob M
