It is currently Wed May 20, 2026 7:47 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Wed Jun 23, 2010 9:45 am
I don't think you can buy the replacement charcoal. I'd sure like to know. Anyway, put a cheap fuel filter in the line that runs to the base of the carb. That will keep debris out. I had the same problem.
PostPosted: Wed Jun 23, 2010 10:27 am
Yeah, I'm pretty sure you can't replace the filter, but I'd like to replace the whole cannister. If anyone has a suggestion on that, it would be a huge help!
Thanks btw!
PostPosted: Fri Jun 25, 2010 10:47 am
YearOne Inc. has them.
Do a search on line and look in their MOPAR "A" body catalog.
As a quick fix when they rupture like that put a fuel filter between the canister and the carb. That will stop the charcoal from entering the carb vent.
 Post subject: Charcoal
PostPosted: Fri Jun 25, 2010 12:43 pm
Go to an aquarium store /the activated charcoal they put in aquarium filter is exactly the same. inexpensive also
hope that helps
Regards MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
 Post subject: oops
PostPosted: Fri Jun 25, 2010 12:45 pm
Buy the charcoal that is in a sealed cloth bag...........also the filters for icemakers are the same activated charcoal.
max
1966 barracuda 360
PostPosted: Fri Jun 25, 2010 12:52 pm
Activated carbon/charcoal from a pet shop (aquarium supplies)
You can also get the little filter bag there.
Or get what is essentially a filter bag from Michaels or Joanns craft stores. (wedding supply). Filled up a bunch with the activated carbon and attached to the underside of my bench seat to take care of the musty odor....
