It is currently Sat Jul 18, 2026 7:11 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Jun 27, 2010 2:52 pm
I had problems flushing out my brothers cooling system on his 65 newport.
long story avoided - we had to turn on the heater - to allow the coolant to flow all thru and flush out the heater box wich was hiding a bunch of yucky stuff in there.
so next flush - turn on your heater.
run the car a bit
drain and re fill
run the car more - turn on the heater again for 10 min.
drain again and then refil with proper coolants
and then good to go.
1972 Plymouth Valiant / slant 6 auto
 Post subject: Re: Cleaning radiator
PostPosted: Sun Jun 27, 2010 6:30 pm
....if you use de-ionized water (i.e. distilled) for your coolant mix your "grubby" water should go away eventually.
De-ionized water is not the same thing as distilled water.
De-ionized water is water that has been passed through a membrane or media that removes ionic compounds, but leaves nonionic compounds in place.
Distilled water, on the other hand, is the trapped condensate from a distillation process and is pure H2O.
For the purposes of this thread, they both provide the desired effect as it is typically the dissolved salts (ionic compounds) that gunk up a cooling system. The de-ionized water doesn't have these in it, and the distilled water is nothing but water.
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
Users browsing this forum: Amazon [Bot], Google [Bot] and 34 guests
