It is currently Wed Nov 25, 2026 11:24 pm
PostPosted: Wed Jul 16, 2003 9:46 am
I am trying to decide what is required for my car (72 Dart Swinger /6). 35k mile on the odometer, I drove it home at 70mph, one hour. It now has a new air filter, the oil is a tad over full and dirty so it will get an oil/filter change. Would an engine flush hurt before the new oil? What is a good oil (synthetic or not)? Should I change the fuel filter also? Any other suggestions appreciated. The car starts/runs great and has no leaks. I am just not sure how much I need to do since I don't know the last time any of this was done.
PostPosted: Wed Jul 16, 2003 10:25 am
Not knowing what the previous owner did, but everything seems to run fine...
Change the oil and filter, replace the plug wires, plugs, rotor and cap, fuel filter, and air filter, have the cooling system flushed (especially if you don't know if it's ever been flushed). Have the tranny fluid checked. Get it lubed. Check the shocks for leaking, check the rear cover of your differential for leaks.
If you really want to get technical you can check your valve lash and make sure it's on spec. and reset the timing....
PostPosted: Wed Jul 16, 2003 10:35 am
I'll add two things. Change the crank case breather, ie the PCV and the breather cap (or clean with carb cleaner) and go over the electrical contacts to make sure all connections are good. Congratulations on your new car! 8)
 Post subject: Good call eric!
PostPosted: Wed Jul 16, 2003 10:53 am
You know I forgot to even add those two and they are pretty important...
cool!
PostPosted: Wed Jul 16, 2003 3:50 pm
Thanks DI and Eric, shocks are good and no leak from the rear diff. I think I will go ahead withe the full tune up, I was just a little wary of messing with something that is running so well.
PostPosted: Wed Jul 16, 2003 4:44 pm
It may be running well, but it can always run better! :twisted: 8)
 Post subject: brands
PostPosted: Thu Jul 17, 2003 1:33 am
It might be helpful, and I'd like to know myself, what brands work best for the abovesaid parts?
PostPosted: Thu Jul 17, 2003 6:12 am
I use Wix filters (Carquest brand is same), and Standard Ignition parts (Blue Streak if available), and NGK V-power plugs.
PostPosted: Thu Jul 17, 2003 11:26 am
I use Napa Gold oil filters (also made by Wix) and Autolite Platnum #66 plugs. Fram air and fuel filters have never let me down (I change them twice a year though), just stay away from Fram oil filters! I lost 10psi on the last two I used. Puroilater is also good.
PostPosted: Thu Jul 17, 2003 1:10 pm
Do you mean that you were running 10PSI lower than normal while using the Fram filters? I've always avoided Fram as much as I could, but not necessarily for that reason. My personal favorite is K&N (though their air filters are a bit iffy for me). I use the same filter for the Dart that goes into my truck, so I've usually got one handy, too :P
PostPosted: Thu Jul 17, 2003 1:30 pm
Yes, I lost 10 or so psi. Haven't run them for over 2yrs now. Funny thing is, I never had a problem when I used them on my 400 and 383 I had in my Fury for over 15 years (nor did my dad when he owned the car). I used the short filter (PH43).
