It is currently Wed Nov 25, 2026 9:13 pm
 Post subject: Choke Stove questions...
PostPosted: Tue Jul 15, 2003 9:56 am
Hey....got some questions about choke stove/exhaust manifold/carb. compatibility. I've got a later model exhaust mani. with the choke pocket that has one side wall missing. I'm going to install it on a 63 valiant with a stock Holley 1920. Can I use the original choke stove that is on my car?? I've got the original exhaust mani. on there now. If not, which style stove will work with this combo.?? Anybody have one that'll work??
Thanks.....G.
PostPosted: Tue Jul 15, 2003 10:37 am
Find a late model choke stat, or better yet, see if Idiot Auto parts has one for, say, a 78 Dodge aspen with a 1bbl slant six. The only problem with these is that they usually have a little heat element built in and it may open a little slowly for you without that hooked up. There may be an earlier one w/o the element, anyone have any input on this? I've run the late style without the element hooked and had no problems.
"DW"
If it ain't broke, fix it!
PostPosted: Wed Jul 16, 2003 8:30 am
The choke stat on on my 1987 D150 truck, Slant 6 Holley 1-bbl, has a few more wraps to the bi-metal coil and seems to be faster opening than others that have fewer wraps. It has the electric heater too. Still opens faster even when the heater does not operate. Hey, why not add the thermo switch for the choke heater if you use one on a early car? Get the later round one from a late 70s or 80s slant. It's a lot better than that rectangular one used in the early-mid 70s.
PostPosted: Wed Jul 16, 2003 10:47 am
There may be some compatibility issues using the new choke thermostate with the Holley 1920, since they where used with the Holley 1945. At the tip of the rod, where it goes into the choke linkage on the carb., is bent differently, so either modification of the rod is required or you can remove the rod from the original thermostate and install it into the new thermostate.
PostPosted: Wed Jul 16, 2003 10:56 am
Good point on the rod difference. On a car with choke "issues", I often like to cut the rods (cut each one longer than it needs to be) and put them back together side by side within a small piece of vacuum hose. This allows me to adjust the choke tension as desired.
"DW"
PostPosted: Wed Jul 16, 2003 10:30 pm
Oh, that is right! The carb end of the rod is bent rearward for one carb and forward for the other carb, at least on the early-mid 70s stuff I've worked on. I don't know how the lenght compares. The rod can be swapped on the later choke stats from 1973-up. I'm not familiar with how far back they used that style choke stat. The ones in the 60s were completely different as you probably already know.
