It is currently Fri May 22, 2026 9:03 am
 Post subject: carb??
PostPosted: Thu Jul 01, 2010 9:38 pm
awhille back i posted that i needed help my car was smoking and it smelled like gas . i did a braekdown of my carb{kit} and noticed that power valve lever was missing a washer retainer and a ball bearing they where loose in the carb??? found them inside and noticed that where the lever inserts into the main well body there is missing a cap ??? and spring ??? but there was a ball bearing inside of that hole ??? would any if this issues cause my car to run rich thus smoking? i changed the valve oil seals already . and where can i get that specific parts ????[/img]
PostPosted: Fri Jul 02, 2010 5:26 am
Car Model: 1968 A108 225/3 on the tree
since u haven't said what carb ur playing with my best suggestion is. . . . . . .
since u apparently have dissected ur carb quite extensively, get a rebuild kit for it now and finish the job. follow the instructions in the kit should get u a fresh carb, and get rid of that gas smell.
D~~~!
PostPosted: Fri Jul 02, 2010 11:38 am
it is a 1920 holley but what about the missing parts ????? if any ????
PostPosted: Fri Jul 02, 2010 12:29 pm
The 1920 shouldn't have any ball bearings rolling around inside. Can you take some nice detailed shots of your metering block and inside the Carb?
~THOR~
PostPosted: Fri Jul 02, 2010 9:22 pm
i took some pics but do not know how to paste here can i pm you then send pics . the bearings came out from the power valve lever the second stage hole ? put that bearing back but then i noticed that where the lever enters into a hole in the main well econimizer part there was a bearing which fell out and i think there should be something holding it i ?????? like the power valve second stage ??????????
Users browsing this forum: Bing [Bot], RumDungeon and 9 guests
