It is currently Thu Nov 26, 2026 1:18 am
PostPosted: Thu Jul 17, 2003 5:20 am
Hey guys i'm back with some more updates, and other info... First I got a lot of stuff back flushed out of my system, and I was able to break threw so the drain plug is now flowing freely... seams to be running much cooler now. Also I went to pull the thermostat. While reinstalling I felt something crack... so i started to back flush the system again, then noticed water coming out of neck... well the lower bolt ear on the outlet broke. I went to pull the outlet off my 77 and noticed my 77's has extra support metal angles there where my 67's broke... two of them, does anyone know what year they started doing this? also the brake on the 67's looked dirty, like it been cracked or cracking before. This makes me assume this was a problem.
Mike C
http://cuda.iclownz.com
67 - Barracuda Coupe - 225 - Automatic
PostPosted: Thu Jul 17, 2003 11:32 am
I think the extra gussets started in '73, since the original engine in my Satellite didn't have it and the '73 engine I put in did. Did you back flush the heater core seperatly from the engine? Also, when I pulled out the block plug, I put a brass petcock valve in its place to help in draining the block in the future. Just a thought.
PostPosted: Thu Jul 17, 2003 6:01 pm
Yeah I put in a valve. and yes I back flushed the core separate.
Mike C
Users browsing this forum: DuckDuckGo [Bot] and 1 guest
