It is currently Wed May 27, 2026 5:02 am
PostPosted: Tue Jun 29, 2010 9:15 am
what are the clearences?
PostPosted: Tue Jun 29, 2010 9:45 am
6 Pack Dart
Stock cam or aftermarket ??
PostPosted: Tue Jun 29, 2010 11:58 am
all stock
PostPosted: Tue Jun 29, 2010 1:13 pm
I use Intake .012 & Exhaust .024
PostPosted: Tue Jun 29, 2010 4:02 pm
Do it right, start it up, get it warm. Shut it off, pop off the rocker cover. Restart, drop the rpms as much as you can and keep it running and adjust your rockers. Doing it right makes very little mess.
PostPosted: Tue Jun 29, 2010 7:16 pm
I agree, but Ems figures are a good place to start on an engine rebuild.
Sam
PostPosted: Sun Jul 04, 2010 7:08 pm
I set mine to the hot specs while cold and leave it.................
now donning fire suit :P
PostPosted: Sun Jul 04, 2010 8:12 pm
no fire from me,......I sometimes warm it up....shut it off .....and do it static.....
PostPosted: Mon Jul 05, 2010 5:58 am
I recently did a running adjustment for the first time and will never go back to the other way.
It gets a little oil on things but it's easily wiped up.
1954 Ford, Tudor Mainline
1976 Plymouth Valiant, 4 door
www.automotive-ninja.com
PostPosted: Mon Jul 05, 2010 9:32 am
Well I set mine to cold specs while hot. Nyah. :lol:
NOT! :roll:
Cold right after bolting the engine back together, Emsvitil gives you a good starting point. Loose enough to fire up and idle, tight enough that the parts aren't flopping around.
 Post subject: less mess
PostPosted: Mon Jul 05, 2010 4:54 pm
Car Model: '63 Dart GT Convertible
One thing I do to have less mess is to take a couple minutes and remove the fan. Keeps the air down. I set mine on 12&24,hot (truck specs).
ifyoubegintothinkyou'relosingcontrol...it'salreadygone
 Post subject: Re: less mess
PostPosted: Mon Jul 05, 2010 7:12 pm
Where did you find that spec? I have never heard of that for a slant six.
Users browsing this forum: Google [Bot] and 15 guests
