It is currently Sat Oct 10, 2026 10:26 pm
PostPosted: Fri Jul 02, 2010 11:54 pm
its appreciated DI but i got it covered, little sheet metal, some jb weld, 2 intake/exhaust mani studs 2 nuts and one misc bolt, 2 spacers ( one was from a chunk out of long spacer for my rear sway bar end links, the other was a 5/16 tube nut)
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sat Jul 03, 2010 4:52 am
Does your set up include heated air for the air cleaner?. This will help with cold drivarbility. I think it is a part that bolted onto and around the stock exhaust manifold.
I think your block off plate is a good start, but honestly is too thin to last. It is so much trouble to take off that intake exhaust/combo, I would encourage you to take your sheet metal plate to a machinist, or metal worker and have a 1/4" plate made as Joshua recommended. It will save you much time in the long run. Your back will thank you for it. :wink: Not only that, but if you put a thicker plate in there, you will get the needed heat transfer to make life better in the cold weather.
Good luck, Sam
PostPosted: Sat Jul 03, 2010 5:56 am
Also a quick note. Watch out using Galvinized metal. The burning product can kill you.
Just my 02.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
 Post subject: Yep...
PostPosted: Sat Jul 03, 2010 8:05 am
The fire rating for that thin of sheet metal is about 1-2 hours...The fumes from heated galvinized( the zinc) will make you sick and send you to the hospital (in my trade you have to wear a filter mask and a welding hood to weld on it).
From previous experience with bolting on plates to use with the Dutra split manifold I would shoot for 3/16" plate, and if you mix is OK you can use the Bronze RTV...JB weld I think holds up to about 300-350 degrees (exhaust is in the 4-500 range if tuned...and up to 1000 if you are reallly lean).
PostPosted: Sat Jul 03, 2010 12:59 pm
well i know about the fumes from galvinized steel, but this is just a patch, I have header flanges (off ebay) on order, I have a buddy of mine swinging by today and I will got get raped at home depot for some sheet steel, it was me just seeing if it #1 i could do it, and #2 if it might survive engine break in, but i will fix it once i get my sheet steel.
now what kind of mounting spacer is need to go between the cliffy intake and my eddy carb ??
-Mike
PostPosted: Sat Jul 03, 2010 5:24 pm
THAT'S WHERE YOU WANT TO USE THE WOOD.........BEST INSULATOR AND ITS FREE ALMOST
Max
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Sun Jul 04, 2010 3:41 pm
working on a 2" spacer as we speak (i know kinda thick but the wood was free lol) since my cliffy came with no carb adapter I got to engineer one !!
also I have a edelbrock 1405 series carb (it was also free :D) now my 2 questions are can i get rid of the AUXILIARY VALVES & WEIGHTS #42
http://www.edelbrock.com/automotive_new ... 0/1477.pdf
and can i make all 4 barrels open at once VS front 2 then at half throttle rear 2 begin to open ??
-Mike
PostPosted: Sun Jul 04, 2010 5:23 pm
update heres my carb spacer, total time to make 1.5hours ( most of which was drying time for the glue)
-Mike
PostPosted: Sun Jul 04, 2010 5:41 pm
Be sure to use a gasket on each side..........I've been doing these wood spacers for years and they always work perfectly. I even ran a 9:93 with wooden spacers on a tunnel ram. I'm old school, really old school. I'm surprised someone hasn't tried to tell you differently. Make sure it's flat!
MaX
1966 barracuda 360
PostPosted: Sun Jul 04, 2010 6:20 pm
I like that spacer! 8)
'78 Volare 225
'67 Charger 318
PostPosted: Sun Jul 04, 2010 6:27 pm
Now he has the makings of a REAL hot rodder. No parts changer at home here........... :D
MaX
1966 barracuda 360
PostPosted: Sun Jul 04, 2010 8:02 pm
cheapest spacer i could find THAT WOULD work but still need to be modded-------$29 (1"alum)
mine--- 2" wood with the correct bolt patterns (wood was free $4 for the 5min epoxy) total $4
Free edelbrock 600cfm carb
carb rebuild kit w/free marine accelerator pump seal $21
getting it running before i die...... PRICELESS lol
-Mike
PostPosted: Mon Jul 05, 2010 9:49 am
UPDATESSS !!!! well i had to stop started messing stuff up oh yea it ws also 630 in the morning.......... i started working on her at 6pm an and off till about 8pm then hard charged throught the rest,
now off to finish her,
-mike
PostPosted: Mon Jul 05, 2010 11:09 am
looks like it'll work .................now for a nap eh?
regards,
MaX
1966 barracuda 360
PostPosted: Mon Jul 05, 2010 12:00 pm
i got about 5 hours, could hardly sleep so close to done its scary lol
-Mike
Users browsing this forum: Bing [Bot], Killer6, Plymouth_Ruster and 15 guests
