It is currently Tue May 19, 2026 9:15 pm
 Post subject: Leaky Harmonic Balancer?
PostPosted: Tue Jul 06, 2010 5:43 pm
OK,I have a BH block and a Rollmaster balancer.I have had a on going leak/seep around the front cover and balancer.Is there supposed to be a oil slinger on the end of the crank inbetween the crank and timing cover?If so does any one have on.This leak drives me nuts.The engine has been to 2 diffrent shops for building and blowing up but I can't stand the leak.Took it apart and I think that in all the other motors I have done there is always a slinger.Please contact me if you have one,I would really like to put it back to gether CORRECTLY! :oops:
SOOOOO much money spent and I keep gettin' told that I could have had a V-8
PostPosted: Tue Jul 06, 2010 6:04 pm
Hey I'm down in Phx. I do know that they make a sleave that goes over the balancer, they are more for seal groove wear. I do not know about any "slinger", never seen one in a slant. Have you been changing the timing chain cover seal?
,Cliff
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Tue Jul 06, 2010 6:47 pm
YES YES .............there is a slinger and they are interchangable as far as I know. They are there for a reason.........timing chain must have oil. I commend you for wanting to do it right. I know a 440 will work as I couldn't find mine so I used the one off a RB B should work also ....be sure to put it on in the right direction........best regards
MaX
1966 barracuda 360
1964 signet conv. 170 turbo
Bonneville or Bust 2012
PostPosted: Tue Jul 06, 2010 9:38 pm
Drill the two holes in the timeing cover a bit bigger where dowels go tru.With new seal and gasket on, put the cover on loose.Put damper on,centering seal on the damper with the cover loose I turn the motor tru while tightening the cover.It is now centered perfectly.Anouther seal trick is you can take the spring out of a seal and un thread it at the split,snip a little off and re thread it back together,tightens up the tension on the seal a little.No leaky Guzzi Mark
PostPosted: Tue Jul 06, 2010 10:01 pm
If you are getting oil through the center hole of the damper put a little RTV on the inside of the hub before you reinstall the damper.
PostPosted: Wed Jul 07, 2010 5:39 am
Brand new Mopar Oil Slinger here
http://www.chicagoconnection.us/index.p ... cts_id=630
Martin Zappettini
1974 Dodge Polara RT 318cu.
1965 Valiant III Coronado Slant Six 6-Pack (soon!!)
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 23 guests
