It is currently Thu Nov 26, 2026 5:10 am
 Post subject: Cam help.
PostPosted: Wed Jul 16, 2003 4:12 pm
I need help choosing a cam for my engine buildup. I have a a '65 block with:
  • clifford intake
  • holley 390
  • headers
  • .060 overbore
  • big valve ported head
  • 8.75 rear end with 3.23 and 3.55 gears
  • 2800-3000 stall converter, haven't gotten this yet
  • still looking for '68 and up forged crank
I was planning on using the .528 mopar cam, but I've been shying away from it after hearing about some of the recent problems. I just got off the phone with Comp Cams and the person I talked too didn't have have much knowledge about the slant. He told me to just give him the specs of the cam I want and they will grind it for me. I may do this, but I would rather work with a grinder that will tell me what will work. This is my first slant buildup and I want to do it right. I want this car to be streetable enough to drive it to the track, race, and drive it home again. I would appreciate any help and or some cam specs that would work well for me.
65' Dart. A work in progress..
______________________
Joe
PostPosted: Thu Jul 17, 2003 6:07 am
Joe,
Yes, I'm leery of using the MP 528 too. Slantzilla just ordered a custom cam (like 0.510" lift and 240 deg @ 0.050") from Comp and talked to a reportedly knowledgable person there. Sounds like it would fit your bill well.
Personally, I have a custom ground (American Cams in LA, may be defunct now) 0.540", 250 @ 0.050" that works great for partial street duty (or all the time if you're a nut like me). Keep in mind that for a long duration cam, you want more static compression to keep low RPM driveability and idle quality. I run about 11:1 on pump premium. This would require block or head milling on your engine, or custom pistons.
You can get crank kits already ground from PAW and places like that.
Sounds like it'll be a screamer,
 Post subject: cams
PostPosted: Thu Jul 17, 2003 3:42 pm
We used a custom cam from Comp's back of the catalog. Under their MP series, we selected the #6610 and #6611 grinds which give .518"I/.533"E and 247°I/251°E @ 0.050".
The tech rep suggested a 108° lobe separation angle, which maybe we should have used 110° or 112°. Still sorting the car out. Out pulls a 2000 5.9 R/T without trying hard. The MP grinds are for the "big" Mopar lifter diameter and do have more area under the curve than the GM grinds most grinders list.
PostPosted: Thu Jul 17, 2003 4:16 pm
I've read a lot of articles on cam designs and watch what goes on here so I get ideas of what works and what doesn't for the next 'mill'.
From what I understand 108 is the 'middle' of the road grind for most cams...106 and 108 supposedly give better torque characteristics, the 110 and 112 give better idle, idle vacuum, better peak power. Some V-8 articles that compared old comp cam grinds suggested that 108-110 is better for signal on carburated car (to help 'anticipate' the need for more go), and fuel injected cars liked the wide lobes 110-114, they also noted that nitrous cars liked wider lobes up to 116.
someone might help 'clarify' some of the ideas these guys 'spew'....as I understand it the wider the lobe displacement angle the longer the valves will stay open (scavenging), and also the longer they will stay shut on the given 'cycles'.
man I gotta go wrench, I'm getting too literate...now educated enough to be dangerous and not know why... :roll:
PostPosted: Thu Jul 17, 2003 5:14 pm
Not as I understand it. The lobe separation angle describes how far apart the peak lift of the intake and exhaust lobe of a given cylinder are in degrees. (or maybe it's how many degrees apart the beginning of the opening of those two valves are, I'm not sure) The lobe separation angle has absolutely nothing to do with the profile, lift, or duration of individual lobes. However, decreasing lobe separation increases overlap, and makes the engine behave differently than it would if the lobe separation were wider. So, you can grind two cams with identical lobes, but give them different lobe separation angles, and they will behave differently. I guess you could sum it up by saying the LSA affects the "position" of the lobes relative to each other, not the characteristics of the lobes themselves.
 Post subject: that makes sense but...
PostPosted: Thu Jul 17, 2003 6:13 pm
Err... LSA is the distance in degrees from the peak of the intake lobe, to the peak of the exhaust lobe. Looks like I got dyslexic, reducing seperation angle does increase the overlap event.
According to many 'comparo' article grinding the same profile with different LSA's, the characteristics of the short LSA: increases torque, reduces idle quality, and can cause cylinder bleed down on long duration cams (valves open too long, I think is what they hint at...), longer LSA makes for good idle, more peak HP, great vaccuum for accessories....
thanks for clearing that up V8440, interesting stuff....
PostPosted: Thu Jul 17, 2003 7:41 pm
Thanks for all of the input. I would like to find out who Slantzilla dealt with at Comp Cams. That sounds like the guy I need to talk to. I believe Charlie Myers lives about an hour from me. I bet he may have some spare parts lying around that he would sell. I may have to give him a call.
Joe
PostPosted: Thu Jul 17, 2003 8:09 pm
I spoke to Tim Cole. :shock:
I'm hoping this cam accomplishes 2 things:
1. Is a little more streetable than the MP 528.
2. Doesn't eat the oil pump gear. :?
PostPosted: Fri Jul 18, 2003 5:44 am
Dennis,
Maybe you should change your handle to "cut the crap"? :lol:
PostPosted: Fri Jul 18, 2003 9:10 am
When it comes to cams, the overlap event is what you really need to look at, this tell you alot about the "manners" of the cam.
DI's discription is pretty close but I have alway thought that a short Lobe Seperation Angle (I call it "lobe centers") like 106 degrees or less, will reduce low speed torque and increase high RPM H.P. while the wider LSA like 110 degrees or more, will build torque at the expense of high RPM H.P.
The LSA defines the amount of overlap the grind will give you. This is not the same as the "Installed Centerline" which is where the intake lobe is positioned in respect to TDC. ( These two cam features are often confused).
Clear as mud.... :? :wink:
PostPosted: Fri Jul 18, 2003 9:19 am
Tighter lobe separations also make for a peakier powerband, with a higher peak and a quicker falloff on either side of the peak. A wider lobe separation grind won't have as high a peak, but will give better performance on both sides of the peak. That's the major reason why nitrous cams are generally docile in everyday driving.
PostPosted: Fri Jul 18, 2003 3:30 pm
Clifford has a whole series of cams ground specifically for slant-sixes in various levels of power and engine build-up. Also, Comp Cams "260 series" works well in an inline six. I haven't put one in a slant six, but I built up a bow-tie 250 inliner with one of their cams and it worked very well. The engine was set up with a Clifford intake, Edelbrock 500 4-bbl, Accel ignition and Heddman dual output headers with a couple of cherry bomb glass-packs under my seat. :roll:
It ain't what you buy, it's what you build!
PostPosted: Fri Jul 18, 2003 10:31 pm
A LOT goes into making a custom camshaft. I have had several custom cams made over the years. You really need to talk to someone with great knlowledge and experience. Generally, I have found the guys you talk to at the cam companies do not have the background to offer any real good advice. You cannot look at any one spec on an engine and say this or that will work. Someone shoot an email to http://www.flowtechinduction.com/
Ed has been very succesful with Fords, but he does work for Nascar as well. He has great experience, is an engineer, has developed cam profiles used by Comp Cams and makes great custom camshafts. He's a very nice guy to deal with and very approachable.
Mitch
PostPosted: Sat Jul 19, 2003 9:23 am
Dennis,
Waddya sayin'? :shock: :shock: :shock: :D
PostPosted: Sat Jul 19, 2003 10:21 am
Mitch
Mitch is spot-on about cam design, there is so much to know and lot's of complexity, that makes it hard to for anyone to find or grind the perfect cam, each engine is different and need a different grind.
I have a grinder in my area who has the knowledge but I have to give him tons of engine data (an $$) to get a well designed cam / grind for the "one off" race Slants I build. Head flow numbers and cranking compression PSI are two key pieces of info. this grinder wants / needs to "get it right".
Anyway, if you are really serious about performance engine building and cam design, here is a way to learn more about the subject and how to make all the parts work together.
Dema Elgin or Allan Lockheed as individuals have so much engine knowledge I can spend hours talking to them, put them in the same room and that will make your head explode! :shock:
If anyone wants to go to this seminar let me know and I could likely work-out a special deal for a group.
http://www.dutra.org/pictures/misc/elgin-lockheed.jpg
Users browsing this forum: Google [Bot] and 7 guests
