It is currently Thu Apr 30, 2026 10:38 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Fri Jul 09, 2010 7:40 am
just a quick update on this. I ended up buying one of these from Oz, but I did not install it since it is missing the split-shoulder at the bottom of the gear, otherwise it would be a direct replacement. Maybe one day I'll send them an OEM one to see if their shop can make one like it economically. It should be relatively easy for a good machine shop to make one if they're already set up to make the other style.
PostPosted: Fri Jul 09, 2010 8:02 am
Why does the lack of the slot on the bottom of the gear bother you?
