It is currently Wed May 13, 2026 4:36 am
 Post subject: holly 2280 wont idle
PostPosted: Fri Jul 09, 2010 11:29 am
I have a new holly 2280 (bought it a couple of years ago from S6Dan)
that wont idle. Like i said the carb is brand new but has been sitting around for quite a while. I put it on my freshly rebuilt 75 solid lifter motor and she just wont idle.
i have it off and apart and cleaned everything out as best i could but still no idle
any suggestions would be appreciated
thanks
Dean
PostPosted: Fri Jul 09, 2010 2:13 pm
Sounds like a vacuum leak somewhere. Either in the base gaskets or the intake to head gasket. Leaks can also come from using manifold to carb adaptors.
PostPosted: Mon Jul 12, 2010 8:06 am
thanks for the suggestion but it didnt help
i checked everything with an unlit propane torch with someone on the throttle to keep it running and no leaks.
the only way i can get it to idle (and very poorly at that) is to block off the top of carb about 90% with my hand
its a new carb (not rebuilt) and i am stumped
thanks again for the suggestion
