It is currently Tue May 12, 2026 6:48 am
 Post subject: Turbo /6 build
PostPosted: Mon Jul 12, 2010 7:01 pm
I plan to turbo a /6 in the future and need info on whats needed and what combo I should go with. Itll be in a 78 D100 shortbox. Id like it to be streetable wich most turbo vehicles are. Id be happy with 11-13 range for times. I have a 67-8 motor or a 80 to start with. What pistons, turbo, cam, rockers, head work rods. Thanks for any info given. :D
Mopar: It's a Lifestyle
PostPosted: Mon Jul 12, 2010 7:28 pm
If your adding only 10psi, a stock motor will work and produce decent power there is many ways to do induction and exhaust so you will have to decide how safistacated you want to get.there is a thousand different options. what is your goal?
Nick
86 d150 turbo /6.
PostPosted: Mon Jul 12, 2010 7:40 pm
I have a stock lower end with Federal Mogul forged pistons. I think these are no longer made. But there are other forged pistons that will work with the right rods. Someone is bound to come on and fill you in. I did rather agressive head work, porting the valve guide bosses inside alot so they are very smooth. The slant six head is the major weakness in the end.
I had the head trued up, and ended up with 8;1 calculated compression ratio. I think maybe this is too high. When I get boost over 9 psi, I get into preignition. I would try for 7:1 maybe. That is just my opinion. Others will have their theories as well. And they will come on and offer them for sure.
Good luck, Sam
PostPosted: Mon Jul 12, 2010 8:20 pm
Thanks sam
Turboram I gues my goal is a 12sec or so street truck
PostPosted: Tue Jul 13, 2010 4:58 am
Well my truck is lightend to 3700,runs drag radials, use nitros to launch, and boost the head gasket right out of it. all for a mid 11 quarter.
without nitros I run mid 12s. but its tough to get the weight moving with a little motor
by the way Sam I run a 8.6 CR and 18 psi of boost with no knock, maybe its time for a little water/meth for you
Nick
86 d150 turbo /6.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
