It is currently Wed May 27, 2026 2:38 pm
PostPosted: Wed Jul 14, 2010 6:12 am
I've got two 1973 1920 carbs. carb #6594 and 6593. I'd like to swap metering blocks but the metering blocks are physically different. One looks like the normal metering block with all vertical passage ways the other one has a passage way towards the top that goes off at an angle and is stamped '73'. Has anybody run into this? I had assumed the metering blocks were pretty much interchangable.
Users browsing this forum: Ahrefs [Bot] and 5 guests
